Click for Westport Click for Ocean Alexander Privacy Matters Click for YF Listing Service Click for Delta
41' Hatteras Convertable
Discussion in 'Hatteras Yacht' started by joesig, Aug 10, 2009.
  1. joesig
    joesig New Member
    New Orleans, LA
    I have been looking at the 41' Hatteras convertable's and have herd about the cored hull bottoms on some models. What year did they stop using this method? I know the corring is used on the hull sides but dosen't seem to be an issue.
    Thanks,
    joesig
  2. grady
    grady New Member
    gulf coast
    Joesig
    I have also been looking at 41C's in the 1980s.
    The Cust Service folks at Hatteras can advise you if a specific hull ID# has a cored bottom. I have supplied a hull ID# of a 1986 41C and they were able to confirm that it was a foam cored bottom. Although I was not able to get confirmation of exact yrs and qty of 41C built with cored bottoms, my understanding is that there may have been as many as 25 built with cored bottoms.
    With a specific hull ID# they will confirm construction.
    Hope this helps
    Grady
  3. joesig
    joesig New Member
    New Orleans, LA
    cored bottoms
    Grady,
    Thanks for the information, I followed up with the factory by providing the hull ID numbers on the boat I was looking at and they confirmed it had a cored hull bottom.
    Thanks, joesig
  4. grady
    grady New Member
    gulf coast
    Joesig
    What year boat was it and does the cored bottom eliminate it from your consideration?
  5. joesig
    joesig New Member
    New Orleans, LA
    41 C Hatteras
    Grady,
    It was a 1986 41 C Hatteras. After finding out from the factory it had a cored bottom I decided not to consider the boat.
    joesig
  6. grady
    grady New Member
    gulf coast
    Joesig
    I too am afraid of the cored bottom boats although the 86 41C is a good looking boat otherwise. I am still not completely sold on the Galley up layout but do like that boat style .
    What are your thoughts on the power you have been finding in the 80s SF boats ( ie 6V71 @ 465HP vs 6V92 @ 550HP)
    good look in your search
    Grady
