| |  | Hatteras 43' dcmy 1970's |  | | |
04-09-2009, 09:50 AM
#16 | | Senior Member
| Quote: |
as to using laundromats, it must be a sailboter thing, jsut like using marina showers...
| No, just a transporter who doesn't like spending the whole day doing laundry. As for the shower...If you don't use it you don't have to clean it, plus, the showers on small boats are...SMALL. As for the "vented" units, I've never run into them on anything as small as a 43. Where exactly do you suggest that be vented to that the lint, heat and moisture won't be completely undesireable?
__________________ "Some went down to the sea in ships." |
04-09-2009, 10:09 AM
#17 | | YF Moderator
| Quote: | Originally Posted by Pascal
The problem about Splendids and other combo units is that people believe incomplete advice found on the web like "combos don't dry well".
the truth is that there are two types of combos, vented or unvented/condensing. The vented models work just as well as any other dryer, it's the unvented models which dont' dry well.
In the past many combo machines had dryers without fans, just heating the laundry which wasn´t very good. I don´t think they are delivered any longer?
The two types today, vented and unvented is basically the same, doing the same job. The difference is that the condense dryer is cooling the outgoing air and keeping the water in a "box" when the other type is venting it out in the room or to the outside.
What is making a difference though is if the dryer has sensors or just temp and timer.
04-09-2009, 10:21 AM
#18 | | Senior Member
Join Date: Oct 2006 Location: Ft Lauderdale, Florida/Avalon NJ/St John USVI
| AEG Appliances
We have units from AEG. Built in Germany and they kick butt. Only 23" across the front, both are front loading so they are efficient and AEG makes a rack to stack them if you like.
We run them while underway with no problem. They both have all kinds of settings (you know; rinse and hold, soak, extra rinse, quick wash, etc.) The detergent drawer in the washer has different slots for pre-wash detergent, main wash detergent, bleach, fabric softener, water softener, and starch so you can "set it and forget it"! The dryer has real live sensors so it actually does what it supposed to and stops. Also has a timer function and "air only".
They are a little pricey but I've never had a problem and I run at least 10 loads a week through them. (Lots of heavy beach towels.)
Regarding "Miele" mentioned above; we have other appliances by them (ceramic cooktop & electric grill) and are very satisfied with those too.
Good luck!
ROCKY
04-09-2009, 11:06 AM
#19 | | Senior Member
Join Date: Feb 2006 Location: Sarasota/Ft. Lauderdale FL
"No, just a transporter who doesn't like spending the whole day doing laundry. As for the shower...If you don't use it you don't have to clean it, plus, the showers on small boats are...SMALL."
Amen to that! Plus you get all the hot water you want out of most marina showers.
04-09-2009, 01:04 PM
#20 | | Senior Member
the vented models are as the name implied vented to the outside. The duct is often routed to the ER vent box for instance. They work just like a regular dryer. really no difference except that being 120v they take a little longer...
i dont' know... i've never use marina showers! even when i have smaller boats, having to walk down a dock to public showers never appealed to me. Even on my old hatt we dont' run out of hot water.
04-09-2009, 01:42 PM
#21 | | Senior Member
OK, let's start with the basics. You don't usually go strolling down the dock in bathrobe & slippers.  Just grab your shave kit and drop your towel under your arm.  Most better marinas have fairly nice facilities.
04-09-2009, 03:33 PM
#22 | | Senior Member
| Quote: | Originally Posted by rocdiver We have units from AEG. Built in Germany |
My Mother in Law has an AEG Princess Lavamat which is now over 30 yrs old, two parts have failed- the plastic hose adaptor when moving house which I broke and the front door gasket, I got a hew fitting for the first problem and I rotated the door seal 180 deg for the second till I could get a new one.
I specify Miele gear when getting the chance as these are almost indestructible in all models home and professional.
__________________
Cheers,
K1W1
04-09-2009, 03:53 PM
#23 | | Senior Member
Ge, thought for a moment that was an AIG unit, whew, close...lol...
04-09-2009, 04:20 PM
#24 | | Registered User
| Quote: | Originally Posted by dennismc Ge, thought for a moment that was an AIG unit, whew, close...lol... |
I don't know if that would be a bad thing, having you clothes sucked bone dry in the blink of an eye might be what you want in a dryer.
04-09-2009, 05:13 PM
#25 | | Senior Member
| Quote: | Originally Posted by Opcn ....... having you clothes sucked bone dry in the blink of an eye |
If that were possible, so would heaven.
__________________
Cheers,
K1W1
04-13-2009, 05:15 AM
#26 | | Registered User
Hatteras installed mine by taking out the stbd. forward bunk. Works very well and allowed other nice improvements one being a full size (24") Kitchen Aid oven.
Ted
04-15-2009, 06:52 AM
#27 | | Registered User
| Splendid laundry equipment
Where can I find info on the Splendid laundry machines? do you know a website? Our problem seems to be the depth of a place to put them on the 43' Hatteras Motor Yacht. Any help appreciated.
04-15-2009, 07:07 AM
#28 | | Senior Member
| Quote: | Originally Posted by Hal Jones Where can I find info on the Splendid laundry machines? do you know a website? Our problem seems to be the depth of a place to put them on the 43' Hatteras Motor Yacht. Any help appreciated. |
Here's one source for Spendide. Others can be found on Google under Spendide Washing Machines. http://www.pplmotorhomes.com/parts/s...VM5 QodDCdYRw
04-15-2009, 09:10 AM
#29 | | Senior Member
that's where i bought mine from, price was the best i could find, shipped on time, although the shipping was a little higher than originally quoted.
The splendid was the only one i could find which would fit down the stairs on my 53 and thru the forward SR door without taking any trim, doors, etc... the specs are on the site.
04-15-2009, 10:31 AM
#30 | | Registered User
What are the dimensions of the closet you are planning on using?
Posting Rules
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are EST. The time now is 05:39 PM. | |
