Click For Affinity
Click for Moonen
Click for Platinum
Click for Oceanco
Click for Westport
Click for Cheoy Lee
Go Back   YachtForums.Com > YACHT & BOAT FORUMS > Motor Yachts > Hatteras Yacht > Triple Engine 114' "Anne O"
Reply
Old 03-13-2009, 09:07 PM   #16
Capt. Bill11
Senior Member
Capt. Bill11's Avatar
OK, lets say I wanted to run the afore mentioned boat on only the middle engine.
Where would I start and what should I do to see if it's feasible.
And besides the oil pumps to cool the gear boxes, what other modifications would be in order.
I have some ideas. But any and all help would be welcome.
Capt. Bill11 is offline   Reply With Quote
Old 03-13-2009, 11:02 PM   #17
Capt J
Senior Member
With some gear boxes like a lot of the ZF's they have a shaft mounted oil pump that lubricates the gear boxes if the engine is not running. I don't know how good this is in the longterm.
I would highly recommend running a lot less propellor pitch on the center engine so you're not running too high of an engine load. But chances are, you wouldn't have good steerage and also the boat would be a nightmare in any kind of sea. It would be easier to run the 2 outside engines (which at displacement speed wouldn't burn much fuel anyways) and not run the center engine. The boat sounds awefully slow for it's size and HP when compared to a Broward or Burger with twin engines.
Capt J is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is Off
HTML code is Off
Forum Jump
All times are EST. The time now is 04:35 PM.
Click for Sea Spirit
Click for ISA
Click for Nautical Structures
Click for Crescent
Click for Heesen
