Click for ISA
Click for Oceanco
Click for Benetti
Click for Moonen
Click for Queenship
Click for Westport
Go Back   YachtForums.Com > YACHT & BOAT FORUMS > Motor Yachts > Hakvoort Yacht > New Build: Hakvoort 45-meter Bluewater Cruiser
Review Tools Rate Review
Hakvoort 45-meter Global Cruiser
Hakvoort Shipyard has announced a new order for an advanced 44.90-metre motoryacht, scheduled for launch in early 2011. Suitable for global bluewater cruising, the yacht will provide accommodation for 12 guests and 12 crewmembers. Designed with a displacement-type hull shape, she will feature flared V-sections in the bow, large overhangs, a moderate deadrise amidships and a canoe stern. Her lines will be kept very low, in particular where the freeboard and superstructure are concerned.
The main deck will feature the main tender at starboard side, a bathing platform admidships and a large tender garage on the foredeck. Located on a raised area forward on the main deck, the wheelhouse will feature a state-of-the-art integrated bridge arrangement. Service logistics are a priority, and the well-equipped galley will ensure fine cuisine for 12 in the dining room.
The upper deck will be reserved for the owners, with a dedicated lounge that opens onto a lovely aft space. Other highlights include a study with Pullman bed and a full-beam stateroom with luxurious his and her bathrooms. Fine ensuite accommodations will also be found on the lower deck, which will contain four guest staterooms, a captain’s cabin and a nanny’s cabin. Crew quarters include a well-equipped mess, four comfortable cabins and smart connections to storage areas and technical spaces. The sundeck will feature a dumbwaiter station, three sunbathing areas, an outdoor shower, bar facilities and a whirlpool bath.
Specifications:
LOA: 44.9 m. / 147’3” ft.
Beam: 9.3 m. / 30’5” ft.
Draft: 2.9 m. / 9’5” ft.
Naval Architecture: Diana Yacht Design BV
Exterior design: Diana Yacht Design BV
Interior design: Peter Marino
Construction: steel hull, aluminum superstructure
Classifications: Lloyds * +100A1 SSC Yacht Mono G6 * LMC, UMS and MCA
Main engines: 2 x MTU diesels rated at 700 kW at 1600 rpm
Generators: 2x 125 kW at 1500 rpm 50hz
Max Speed: 14 knots
Cruise Speed: 10 knots
Range: 5,000 nm
Fuel capacity: 60.000 ltr. / 15.852 gallons
Fresh water capacity: 12.000 ltr. / 3.170 gallons
For more information contact:
Hakvoort Yachts
Havenstraat 22,
Monnickendam 1141 AX, Netherlands
+31 (-299) -651-403
www.hakvoort.com
Review Tools
Rate this Review
Rate this Review:
Forum Jump
All times are EST. The time now is 10:06 PM.
Click for Oceanco
Click for Rybovich
Click for Broward
Click for Dyna
Click For Dockwise
