Click for Lurssen
Click for Lazzara
Click for Shadow
Click for Trinity
Click for Christensen
Click for Benetti
Go Back   YachtForums.Com > YACHT & BOAT FORUMS > Motor Yachts > Hakvoort Yacht > New Launch: Hakvoort 38-meter "Perle Bleue"
Review Tools Rate Review
Perle Bleue is a 38-meter contemporary motoryacht with naval architecture by Diana Yacht Design and designed by Donald Starkey Design. The yacht features a round-bilge displacement steel hull with a good deadrise, level keel and flared bow with a fine entrance angle, and an aluminum superstructure.
Extensive outdoor spaces and lots of interior and exterior luxury enhance both the visual and the material comfort levels onboard to a striking level. As a streamlined successor to Campbell Bay, Perle Bleue benefits from the countless insights only a lifetime of sailing on quality yachts can provide.
Perle Bleue’s modern appearance is enhanced by a number of glass bulwarks on the bridge and sundecks. Heavily reinforced glass also makes up the facia of the balconies at the stern. The streamlined size of the yacht also permitted relatively small engines, higher fuel efficiency and an enhanced range. Improved muffler systems were fitted to both the generators and the main engines, and common rail engines are used to reduce emissions and soot.
Specifications:
LOA: 38 m / 124’8” ft.
Beam: 8.00 m / 27’2” ft.
Draft (half load): 2.1 m /7’ 2” ft.
Displacement: approx. 349 tons
Naval Architecture: Diana Yacht Design
Interior design: Donald Starkey Designs
Construction: steel hull, aluminum superstructure
Classification: Lloyd’s *+100A1 SSC Yacht Mono G6 * LMC MCA
Main engines: 2x diesel Caterpillar C18 DITA
Cruising speed: 11.5 knots
Range at 10 knots: 3500 nm est.
Fuel capacity: 46.600 ltr. / 12600gallons
Fresh water capacity: 10.000 ltr / 2.642 gallons
For more information contact:
Hakvoort Shipard
Havenstraat 22
NL-1141 AX Monnickendam
+31 (0)299 651403
www.hakvoort.com
Review Tools
Rate this Review
Rate this Review:
Forum Jump
All times are EST. The time now is 09:39 PM.
Click for Westport
Click for Broward
Click for Westport
Click for Dyna
Click for Lurssen
Click For Dockwise
