Click for YF Listing Service Click for Ocean Alexander Click for JetForums Click for Nordhavn Click for Walker
Money saving, labor saving tips
Discussion in 'General Yachting Discussion' started by yachtbrokerguy, Sep 22, 2008.
  1. OK, there is incredible knowledge here on this site. How about if we post some tips to make all this boat stuff easier?
    Tip 1. Teak cleaning - K2R Cleaner. Available at your supermarket (at least in the US) is a stain and carpet cleaner. If you get oil stains on a teak deck, from peanuts or potatoe chips or even hydraulic oil, spray this on, let it dry to a powder, and it will absorb most of, if not all of the oil.
    Tip 2. Exhaust soot on tenders - clean the tender, wipe it down with an acrylic floor wax that is soluble with amonia, like Johnson's Future Floor Wax. The soot will get into the floor wax and not the rubber pontoons. Then to clean, use amonia and the dinghy is easy to get clean. The tender also looks good and shiney with the floor wax.
    Tip 3. Stiff dock lines - soak overnight in detergent and fabric softner.
  2. Ken Bracewell
    Ken Bracewell Senior Member
    Somewhere Sunny
    One Magic Product- Mr. Clean Magic Eraser
  3. Seafarer
    Seafarer Senior Member
    Hudson River
    Lemon Pledge on surfaces (particularly glass) while you're away from the boat keeps salt and other minerals from spotting and etching.
    You can also use this in your home shower walls. ;)
  4. C4ENG
    C4ENG Senior Member
    Ft Lauderdale
    Is it true Roll Off will eat the glue out of your R I B tender and cause it to come apart at the most inopratable time?
    Floor wax does sounds quite safe...
  5. Castlerock
    Castlerock Senior Member
    New England
    I just want to check, is it the Roll Off or the On& Off that will eat the glue out of the RIB? I always thought that Roll Off was very mild and On & Off had acid in it.
  6. NYCAP123
    DK about the glue on the dinks, but On-Off didn't do didly for cleaning deisel stains on f/g, but Roll Off was terrific. Anybody care to spritz your dink with both and let us know?:rolleyes:
  7. C4ENG
    C4ENG Senior Member
    Ft Lauderdale
    I spilled something oily on a large rubber fender once and was cleaning it with Roll Off. A man from another boat was walking down the dock and started conversation with me about using Roll Off. He told me he had to take his new R I B in for repair becuase the glued seems where coming apart. He told me the first thing they asked was if he was using Roll Off on the rubber pontoons....
    So then I always wondered...
    Was the company making excuses and blame shifting on owner care for the malfunction....
    Or if it was true that Roll Off is dangerous for glued seems on R I B's.
  8. Loren Schweizer
    Coral Gables/Ft. Laud., FL
    1) Ditch that cheesy 12VDC OEM oil-change pump for a 120VAC unit.
    2) RainX for windows.
    3) For any metal bits, esp. aluminum, that have threads or connect with tight tolerances--and which you might want to undo at the end of the season-- SuperLube ($$$) + a bunch of Q-Tip applicators actually works.
    4) "Money saving, labor saving"??
    Buy your Heineken by the case.
  9. rocdiver
    rocdiver Senior Member
    Ft Lauderdale, Florida
    Ditto on the RainX! We also use it in all of the showers, especially the clear shower doors . . . cleanup is MUCH faster.
    DOUBLE ditto on the Heinie!!
    ROCK
  10. K1W1
    And have it delivered.
  11. ychtcptn
    ychtcptn Senior Member
    Lighthouse Point, FL
    switch from Rain-X to Aquapel. We did it almost a year ago and the windows are still good.
    A little more expensive to start, but doing it once a year will make up for it in time and material.
  12. Fishtigua
    Fishtigua Senior Member
    Guernsey/Antigua
    1/
    Stainless galley sinks, good old ShielaShine, lasts for ages.
    2/
    K2R, we love it.
    3/
    Antifoul Bronze props and rudders with Turtle Wax or Forespar Lanacote, lasts about 8 months. Cheaper than the 'real' stuff at $10 a pot and come haul-out time it comes off with the powerwash easily with no growth.
    4/
    Clean dirty braided docklines by putting them in the aftdeck jaccuzzi on a warm wash with a non-bio washing powder so that the elkhide protection and whipping are not damaged. Rinse off very well.
    Fish
  13. viking 58
    viking 58 YF Historian
    Grosse Pointe Park, MI
    Those things truly are magic. They have cleaned up so many different little areas around the boat.
  14. YachtForums
  15. Capt J
    1.Use whink on windows before rain-xing if they are etched. Just rub a 1ft area with a wet paper towel with whink when you see the etching dissappear, wipe off the whink before it dries, when done rain-x windows.
    2. SS, use Collinite metal wax to polish the stainless, then use Collinite insulator wax like you would wax gelcoat (wipe on, let dry, wipe off) afterwards and the stainless will last much much longer before having to polish again.
  16. LtherSolutions
    LtherSolutions New Member
    This is so true!! They do wonders on everything!
  17. LtherSolutions
    Overspray or pollutions use a clay bar (auto parts store). It will bring back the clean vibrant look. You will need to wax it after cleaning.
