Click for Glendinning Click for Ocean Alexander Click for Burger Click for Burger Click for Northern Lights
Beware of ferries in Spain
Discussion in 'General Yachting Discussion' started by GrahamF, Sep 13, 2007.
  1. GrahamF
    GrahamF Senior Member
    Palma Spain/ South Africa
    This is what happens when you get hit by a ferry when in port. I am not a 100% sure on the story but i have been told the ferry hit this boat in port at it mooring.
  2. C4ENG
    C4ENG Senior Member
    Ft Lauderdale
    Did the ferry back up and hit this guy twice?
    I am trying to firure how damaged occured bow and stern..
  3. K1W1
    Joel- If the ferry hit the bow hard enough to do that damage it could well have shoved the yacht backwards into the dock at the same time hence the extensive damage to both ends.
    I would also guess that their Charter season is over for this year at least.
    http://www.happycharter.de/en/charter-yacht-2145.html#bottom
  4. ERTW
    ERTW Member
    North America
    Is that hull made of plywood reinforced fiberglass? The trim tab thats hanging looks like it was just screwed into a piece of wood then into the hull.
  5. Castlerock
    Castlerock Senior Member
    New England
    It looks like the trim tabs are mounted on a block made of two pieces of wood covered with fiberglass.
  6. GrahamF
    K1W1 is correct i heard that the ferry hit them so hard that the stern hit the wall. I was amazed when i saw the construction of the trim tabs and the swim platform. The trim Tabs were screwed in with screws. At least you know if your trim tab comes of all you need is a screw driver to re-install it.
