Click for YF Listing Service Click for Nordhavn Click for Ocean Alexander Click for Burger Click for Delta
How deep is a Atmosphere in relationship of depth?
Discussion in 'General Yachting Discussion' started by Ladies choice, Aug 18, 2006.
  1. Ladies choice
    Ladies choice New Member
    Florida
    How deep is one atmosphere in relationship to depth?
    I see this posted on submarine websites and it is also on the back of my new watch, which says "water resistant to 5 atmospheres" So how deep is that?
  2. Kevin
    Click HERE for the explanations, but it's basically 10 meters per atmosphere... so 5 would be 50 meters, or just over 160 feet.
  3. airship
    airship Senior Member
    French Riviera...
    I think that what your watch is trying to tell you is that it will accompany you to at least 5 bars, after which it may abscond with the first person who buys it a beer: when was the last time you bought yer watch a beer then...?! (Sorry for that shallow post BTW... :) )
  4. jediwhite
    jediwhite Senior Member
    Viareggio, Italy
    Don't forget pressure at sea level
    Just a quick point.
    Kevin is right about 10mtrs per atmosphere but you have to remember that at sea level you are already at 1 atmosphere, so 5 is only 40 mtrs deep. And 1 atmosphere is 1 bar or approx 14.8 psi
  5. Garry Hartshorn
    Garry Hartshorn Senior Member
    1 Atmosphere = 10m colum fresh water
    SG Freshwater = 1.000
    SG Seawater approx = 1.025
    3.28 ft = 1m
    Yeah around 30 ft
  6. airship
    French Riviera...
    Some bars have the right atmosphere, and some don't. But so long as the Scotch is served on the rocks and the barmaid has an interesting face, I'm usually not too fussy... :)
  7. Kruse
    Kruse Member
    Denmark
    Well...:p
    One atmosphere of pressure is the pressure at the sea surface (1013 milliBar)
    (The weight of the air above you)
    Zero atm (bar) would be a vacuum.
    Under the surface we use Bar or psi (1 bar app. 14.7 psi)
    So... Your ambient pressure (diving?) would be
    1 bar at the surface;
    2 bar at 10m depth of sea water ( 32.8 feet of sea water),
    3 bar at 20m depth of sea water ( 65.6 feet of sea water),
    4 bar at 30m depth of sea water ( 98.4 feet of sea water),
    5 bar at 40m depth of sea water (131.2 feet of sea water),
    6 bar at 50m depth of sea water (164.0 feet of sea water),
    etc.
    You need to remember to ad the 1 bar (atm.press.) of air above water.
    Otherwise yes...
    Every 10 m into the abyss ads 1 bar of pressure.
    A good link above, for more info.:)
    UUUPS...
    Jusst noticed...
    Question answered at no 4 post.
    Sorry.
