Click for Glendinning Click for Ocean Alexander Click for Westport Privacy Matters Click for Delta
Easy against busy
Discussion in 'General Yachting Discussion' started by Teenna, Jul 3, 2006.
  1. Teenna
    Teenna New Member
    Trinidad and Tobago
    The Market has obviously evolved into two major directions:
    The first one is a re-discovered "easy yachting" that involves sailing yachts, even large ones and sport yachts, so called "opens". The easiness comes from a rather simple layouts, often not on more than two decks, compact crew and unformal and therefore "easy" use of them. The boom of this market shows that yachting can have two faces, because
    the second one, a traditional three, four, five or six (etc) is ofcourse still the largest, but obviously not satisfying for everybody. Large amount of crew, formal and through many decks divided life is not so user friendly and appealing to some as it did when it apeared to be the only really "rich" option.
    Perini has changed this tree-four-five deck mentality firstly in the motorsailing field, and Rodriguez group has done it in the motoryachting, both showing and teching to the market that wealth of the owners and the volume of the yacht are not necessary connected.
  2. KCook
    KCook Senior Member
    Phoenix
    And I thought fewer decks mostly meant better performance?
    Kelly Cook
  3. Dhowdodger
    Dhowdodger New Member
    Arabian Gulf
    easy yachting - less stairs to climb;)
  4. Teenna
    Teenna New Member
    Trinidad and Tobago
    The worlds fastest yacht (as they declare:D for the Millenium) is a tri-deck. Two of the worlds fastest superyachts are four and five deckers, KatanĂ  and Extasea.
  5. Garry Hartshorn
    Garry Hartshorn Senior Member
    true but if they cut off the upper decks they would be even faster
