Click for Delta Click for Burger Click for Abeking Click for Glendinning Click for Abeking
PowerKeel
Discussion in 'General Yachting Discussion' started by brian eiland, Nov 18, 2005.
  1. brian eiland
    brian eiland Senior Member
    St Augustine, Fl and Thailand
  2. KCook
    KCook Senior Member
    Phoenix
    Ok, I'm confused. We usually see hard chimes and a nearly flat bottom on planing hulls. But the added surface area of the keel would fight planing? No?
    Kelly Cook
  3. brian eiland
    To quote from their website, "To summarize the results, the PowerKeel version had less resistance at all speeds below 15 knots (on a 36' boat) with the best improvement between 9 and 12 knots. The wake at 9 knots is impressively flat. This hull ideally suits a long range trawler which would like to cruise efficiently at speeds higher than standard displacement speeds."
  4. KCook
    KCook Senior Member
    Phoenix
    Got it. Not really fully up on plane. Real world tests should be interesting.
    Kelly
