Click for Westport Click for Northern Lights Click for Delta Click for Westport Privacy Matters
Yachts in Alaska
Discussion in 'General Yachting Discussion' started by Kevin, Aug 15, 2005.
  1. Kevin
    Thought you all might like to see a few pics from Alaska and Vancouver.
    Ok ok... it's badly centered, but I wasn't the photographer!
  2. Kevin
    Golden Eagle.
  3. Kevin
    My Margot, a Westbay SonShip.
  4. Kevin
    Not a yacht... but boy does this ever look like fun! :D
  5. Kevin
    I have no idea what this is... but I expect it's quite old. Very neat looking IMO.
  6. Kevin
    AlumerciA.
  7. YachtForums
    Interesting... a machine gun mounted on the bow of an inflatable. Did they ever think what would happen if someone shot back? :D
  8. YachtForums
    Alumercia is notable sighting…
    It’s not quite as sleek as most of Heesen’s launches, as it was designed as more of an exploration yacht, but it’s using an interesting propeller/drive system, developed by Schottel. They also supplied the drives used on Octopus, Limitless & Tatoosh.
    Another interesting feature are the storage bays, which includes a “trunk” located on the aft skylounge deck, as well as a slide-out garage in the stern, which houses a jeep. These VriPack innovations resulted in Alumercia winning the 2001 SuperYacht Award.
    Here’s a nice running shot. If you look closely, you can see the large auto-style trunk.
  9. KCook
    KCook Senior Member
    Phoenix
    No fair teasing :p . Got a link that shows that Schottel system?
    Kelly Cook
  10. YachtForums
  11. KCook
    KCook Senior Member
    Phoenix
    Ah so. Pretty popular for tugs, I had no idea they were also found on yachts.
    Kelly
  12. tantetruus
    tantetruus New Member
    Dordrecht
    The old police boats, small marine ships and quite a few other government services in Holland used these; very popular second hand; all rebuild as small yachts.
    Given the origin of Vripack, this choice is not such a big surprise.
  13. Mov-it!
    Mov-it! New Member
    Katwijk Netherlands
    Alumercia in Rotterdam
    I've seen Alumercia in the port of Rotterdam yesterday. Has been a while since she was last sighted in Holland.
  14. 'RoundTheHorn
    'RoundTheHorn Senior Member
    Salish Sea
    Not to burst your bubble...
    Actually if that was manufactured by Safe Boats (http://www.safeboats.com/), then it's not an inflatable. They use foam collars.
    "SAFE Boats International is the sole source manufacturer of foam-stabilized water craft in North America. Working under a set of exclusive patents and licenses allows only SAFE Boats International to utilize a full-sized foam collar system for flotation, stability and fendering "
    In addition, "The Standard SAFE Boats collar system has been proven to stop small-arms fire from penetrating the hull. With the addition of ballistic material placed behind or actually laminated into the collar, it has been shown to withstand ammunition of up to 7.62 mm. "
  15. travler
    travler Senior Member
    roche harbor wa
    the old boat is an asr conversion owned buy a broker in seattle last year it was in lake union
