Click for Mulder Click for Northern Lights Click for Glendinning Click for YF Listing Service Click for Westport
Yachts in Greenwich, CT this week
Discussion in 'General Yachting Discussion' started by CTdave, Jul 21, 2014.
  1. CTdave
    CTdave Senior Member
    Greenwich CT/ Stuart FL
    Hi all...
    A few random shots from around the Greenwich shoreline this past week.
    What's the story on these? The white yacht "Triumphant Lady" has been here for a month or so. There was a similar one two years ago that Leonardo Dicaprio called home while filming a movie locally.
    There were lots of people coming & going on the dark blue yacht so I didn't want to get too close. Any idea who owns this?
    The one on land is at Norwalk Cove Marina. Looks like she got a serious stretch at some point in her life! With the screws set so far from the transom, how does it affect the maneuvering?
  2. Perlmudder
    Perlmudder Member
    Toronto/Crystal Beach
    Triumphant Lady used to spend a lot of time at Bahia Mar in Ft Lauderdale. Don't know anything about the others.
  3. captholli
    captholli Senior Member
    In The Bilge
    What in the world are the four square objects on the transom of that unfortunate Burger in Norwalk Cove that someone welded an extension onto? looks to be above the waterline so that would rule out diver plate zincs, Freeing ports perhaps?? Good god its an ugly addition to what was a perfectly good S&S design and looks like it was done in the back yard . Transom has no radius and is just a flat plate of aluminum & doesn't match nor does anything else.
    with the davit back in the cockpit I have to assume a tender is under the sole?
    So sad to see a classic like this with a ****** designed and executed extension.
  4. 993RSR
    993RSR Senior Member
    Annapolis/ Palm Harbor
    For Sale by N&J $8M +/-
    Triumphant Lady yacht for charter
    154.86ft /47.2m | Sterling Yachts | 1985 / 2009
    The 154.86ft /47.2m Custom motor yacht 'TRIUMPHANT LADY' was built in 1985 by Sterling Yachts and last refitted in 2009. The yacht's interior has been designed by Cindy Mason and her exterior styling is by Bannenberg & Rowell.
    Triumphant Lady's interior layout sleeps up to 10 guests in 5 staterooms, including a master suite, and 4 double cabins. She is also capable of carrying up to 9 crew onboard to ensure a relaxed luxury yacht experience. Timeless styling, beautiful furnishings and sumptuous seating feature throughout her living areas to create an elegant and comfortable atmosphere.
    Triumphant Lady's impressive leisure and entertainment facilities make her the ideal charter yacht for socialising and entertaining with family and friends.
    Built with grp hull and aluminium superstructure, she features an ultra-modern stabilization system to reduce roll motion effect and ensure the ultimate comfort throughout your charter vacation. With a cruising speed of 13 knots, a maximum speed of 15 knots and a range of 4000nm from her 51885litre fuel tanks, she is the perfect combination of performance and luxury.
    Amenities
    Air Conditioning
    Charter Triumphant Lady
    Triumphant Lady is currently available for charter, to find out more about this superyacht please contact your prefered charter broker.
  5. Fishtigua
    Fishtigua Senior Member
    Guernsey/Antigua
    That's the old Southern Cross III isn't it?
  6. Old Phart
    Old Phart Senior Member
    I dunno
    Don't think so.
    Southern Cross III
  7. 993RSR
    Triumphant Lady was Tooth Fairy
    Sterling Triple-Deck M/Y 147'
    Tooth Fairy
    147' Sterling Triple-Deck M/Y
    Boat Name: Tooth Fairy
    Year: 1986
    Last Listed Price: US$ 15,500,000 (09/06)
    Sold: US$ 15,450,000 (05/08)
    Located in St Maarten, Other
    Hull Material: Fiberglass
    Engine/Fuel Type: Twin Diesel
  8. Marmot
    Maybe the stylist thought it would move the CG forward and make up for the weight of the tender.
  9. SFS
    SFS Senior Member
    Tampa
    Oh no you don't.:) Not after all I've let pass by.:eek:
  10. Capt J
    Triumphant Lady gets around. She was in Harbor Island last time I was there in April.
  11. captholli
    In The Bilge
    I was just waiting for that one ! Good grief Charlie Brown!!
  12. YachtForums
    Maybe the depth of the technical superintendent's knowledge goes no lower then the boot stripe. Some grew tired of trying to penetrate the density of superiority so they moved on, like anyone with intellectual maturity would do.
  13. Kafue
    Kafue Senior Member
    Gold Coast Australia
    There was an obscure thread on YF a while ago regarding CG. I believe moving the tender FWD cause the CG to AFT, unless the STBD falangy in the ER is moved to the centre line. Also that the sq. root of the LWL, multiplied by 1.34 can displace CG even further?
  14. Kafue
    Kafue Senior Member
    Ouch! C'mon, the audience to that thread was growing, lets ressurect it.
  15. captholli
    In The Bilge
    Lets not and say that we did!
    I want to hear the members thoughts as to the four squares on the lower part of the transom? If in fact the consensus is freeing ports than one would have to speculate that the money had run out by then if that was the best cosmetic remedy.
  16. SFS
    SFS Senior Member
    Tampa
    Oh no you don't.:) Not after all I've let pass by.:D
  17. Marmot
    I don't know for sure but there were 4 of these things found under the boat near the stern.
  18. captholli
    In The Bilge
    Are you hanging out at the Pink Pussycat again? Haaa haa they might look good on your sailboat are they 327 -L ?
  19. CTdave
    I'll stop by & get a few close up shots of the mystery holes next week. We are in Montauk now after a few nice days on Block Is. Fabulous trip so far with just one rainy day (today).
  20. discokachina
    discokachina Senior Member
    Sorry Triumphant Lady is still Triumphant Lady, the Tooth Fairy is her sistership and has been sold twice since as Aero Toy Store who was last listed at $4,495.000.00 before being sold and is now Matrix Rose who is on the market for $13, 990,000.00 after being repowered.
    Triumphant Lady has been on the market for several years after a major refit in 2009 being priced at $8,900.000.00.
    They along with Southern Cross III were built in Japan's Nishi Zosen yard in the mid 1980s to designs by Sterling Yachts and Jon Bannenberg.
    Southern Cross III is on the market for $10,000,000.00.
    To see their listings search "sterling" on yacht world.
