Click for Ocean Alexander Click for Burger Click for Burger Click for YF Listing Service Click for Cross
Hull Speed
Discussion in 'General Yachting Discussion' started by NorCalBoater, Dec 24, 2012.
  1. NorCalBoater
    NorCalBoater New Member
    California Delta....for now
    Could someone please post the formula for calculating "hull speed?"
  2. Fishtigua
    Fishtigua Senior Member
    Guernsey/Antigua
  3. NYCAP123
    Good morning Fish, and Merry Christmas Eve.
    Being just a normal captain, and no Brainiac I've always determined my most efficient running speed with my gut ("feel") based on my experience. Today I'll also let a Flowscan do my thinking for me. I also check the speed curves supplied by manufacturers from time to time although mostly just out of curiosity. The term "hull speed" was something I never ran across until I joined YF. I still consider my gut a more accurate indicator, 2nd to a FLowscan, because it takes into account LWL, beam, draft, hull shape, weight, current and water depth, but I always like to expand my knowledge. Today, as I followed your link I found that hull speed really isn't used as an accurate indicator, and instead the "Froude number" is used.
    So for the Brainiacs on the Forum, I'm curious if and how many boaters do this calculation to determine their sweet spot.
  4. Pascal
    For Every boat I ran with flow meters, the most efficient speed was always just below hull speed, or 1.3 x sq rt LWL
    Even just a half knot over that results in a drastically higher fuel burn, as much as 30% more fuel for 5 to 10% more speed... On the Johnson 70 i run, we burn 18gph at 9.75 kts... Bump it up just a knot to 10.75 and fuel burn (on the accurate Cat displays) jumps to almost 30gph.
    So while it may not be a very scientific number because if other factors, it is a good start especially if you don't have flow meters
    I tend to use my gut or experience for determining hull speed. Generally diesels are most efficient at 1000 rpms or less (ones that top out at 2350rpms). But hull speed can also be drastically effected by the balance of the boat and where weight is concentrated, such as whether your fuel is in a foward tank or aft tank. But generally I start at idle and take a notice of speed, then up it each 100 rpms, usually you'll see a .5-1 knot gain at slow speeds. When you up it another 100rpms and only see a 0.2 gain, you've passed the hull speed generally......and I back it down 100 or 50 rpms.....You'll also see a change in running attitude or your wake or both.
    The 75' Hatteras I used to run had a 10' extension put on, it had a foward, midship and cockpit fuel tank. When trimmed right at 1000 rpms you'd see 10.2-10.5 knots.....if you got off 30 gallons too much of fuel drained out of the foward or cockpit tank it would slow down to 9 knots at 1000 rpms.......As soon as you noticed it slowing down, I'd valve both engines to whichever tank was too heavy and 30 mins later it'd start picking back up.
  6. PacBlue
    PacBlue Senior Member
    Dana Point, Ca
    Maybe you meant that the hull's most efficent running point (I am assumming based on fuel burn or MPG) usually can be reached by the horsepower developed at 1000 rpm?
    I know of no diesel engine manufacturer who would claim peak engine efficiency is achieved at 1000 rpm for a 2350 rpm engine :(
    Yes the hull's most efficient running speed.
    Diesels burn a miniscule amount of fuel at 1000 rpms or less compared to say 1950 rpms. For example: a 12v71 TI, burns 6GPH at 1000 rpms, at 1200rpms you're looking at double or 12.5 gph, at 1950 rpms 40-45 gph.
    Most yacht hulls are most efficient at hull speeds. It takes a proportionately lot more hp to keep a boat on plane.
  8. PacBlue
    Dana Point, Ca
    So hull speed has nothing to do with engine EFFICIENCY, right?
  9. NorCalBoater
    Wow. I thought it was easier than this.
    My 1984 52' KhaShing CPMY has 300hp 3208 Cats and has a listed weight of 48,000 lbs. The fuel tanks (300 gal each) are outboard of the engines, the holding tank (40 gal) is low in the forward portion of the engine room and the water tanks (100 gal each) are under the aft cabin bed which is slightly to port. I do not know the waterline length.
    At 1000 rpms the speed is about 7 kts as indicated on the GPS. 1500 rpms shows 9 kts and 2000 rpms is 11-12 kts depending on load. WOT in neutral is 2700 rpms and running at WOT gives me about 17kts just under 2600 rpms.
    I found some notes from a previous owner that indicate the best cruise is at 11 kts. Does this sound right?
    I do not yet have flow meters and I have to replace some trim tab cylinders at next spring's haulout. I have not been able to use the tabs to see how these would affect speed and rpms.
    As I plan some trips for next year I am trying to determine my best cruise speed related to fuel burn.
    Thanks,
    Shawn
  10. Capt J
    Not necessarily. How much fuel does a diesel use idling without a load, next to nothing. If you look at a diesel that is turbocharged, the amount of fuel (gph) used per hp made increases exponentially the more rpm's you turn the engine after the turbo comes online.
  11. PacBlue
    Dana Point, Ca
    I would typically make my own speed/fuel burn chart. Since you have a mechanically injected engine with no electronic fuel consumption data output, you will either have to rely on CAT fuel burn data from their manual, using the Cubic Propeller Demand Curve for estimated fuel consumption or install a Fuel Flow Meter System like a Floscan.
    Load up your boat as you would normally, bring it up to full rpms, and take speed readings at max rpm and every 100 rpms below that down to idle. Now you will have to match the fuel data from the CAT manual, and this will give you an estimate of fuel burn for 1 engine at that rpm setting. Multiply by 2 and that gives you your estimated total fuel burn (not including a generator) for that rpm setting. Divide the speed by the total fuel burn and you will get an estimated mpg, and look at your data for the best fuel efficiency point. My guess is that it will line up to or below the 1500 rpm 9 knot range, before the turbos are spooled up.
    At 2700 rpm. you seem to be about 100+rpm low, meaning if all engine parameters are good and the hull is clean, you are a bit over-pitched at the moment. Typically, you would like to see about 2825 rpm at wide open throttle, but that is another discussion.
  12. PacBlue
    Dana Point, Ca
    You are missing the point. Fuel burn at idle with little to no power means nothing to this discussion. By your analogy, an efficent diesel would not be turbocharged, and this is contrary to what is going on in Industry.
    This thread is about finding the most efficient operating setting of the engine in relationship to the resistance developed by it's hull form, hence the opening question on theoretical hull speed.
    Merry Christmas ;)
  13. sunchaserv
    sunchaserv Member
    Carefree, AZ
    To add one more thing, best you know your true waterline length. For sailors in the crowd who already know , the importance of WL is immense.
  14. Capt J
    I already answered the hull speed and efficiency in an earlier post related to the OP's question.
    A turbocharged diesel has a more efficient hp made versus fuel used than a non-turbo'd diesel generally at cruise rpms or the rpm it's designed to run at or 80% load, and makes the engine more efficient with fuel used versus horsepower made or put out in the upper rpm's where you have boost. Under the turbo boost at lower rpm's they're actually less efficient because the turbo is causing a minor restriction, and you have larger injectors which don't meter the fuel as efficiently at lower rpm's. Turbo diesel efficiency might be vital information if your looking at a fully loaded generator that you run at a constant rpm, or a boat that is constantly running at cruise and your looking for maximum speed/performance/fuel burn at cruise rpm. The OP is not.
  15. PacBlue
    Dana Point, Ca
    Sorry, your are not providing accurate information again, I would leave the Engine Analysis to guys like Marmot, etc.
    Marine diesel engines are typically designed for peak output at peak load. I don't know of any manufacturer who would currently design the engine to 80% load or whatever cruise rpm's and accept the aditional 20 - 30% leftover as just bonus. It just doesn't happen that way. They do design today's engines to meet certain emission criteria at defined rpm's, as dictated by the EPA.
    What restriction at low (idle, 1000, 1500???) rpm's does a waste gated Turbo contribute in the combustion process? news to me...
    Today's diesels have their fuel metered electronically, independent of Injector size.
    This has nothing to do with a generator. You stated "Generally diesels are most efficient at 1000 rpms or less (ones that top out at 2350rpms)." and that is not an accurate statement, it just relates to two things: 1. A 2350 rpm diesel will burn less fuel at 1000 rpm than WOT. 2. Hull Speed will be achieved at lower rpms, maybe even 1000 rpms, depending on how the specific vessel was powered.
  16. Old Phart
    Old Phart Senior Member
    I dunno
    Is this your way of stating that a 2350 max rpm diesel is most efficiently operated at 2350 rpm?
  17. PacBlue
    Dana Point, Ca
    No it is not.
  18. Marmot
    Isn't that sort of like saying you are going as fast as you can when you can't go any faster?
    There hasn't been an engine built that didn't produce the same output as the load consumed.
  19. Pascal
    Shawn
    11kts is probably just about the worst speed you can run at. You re burning twice the fuel you would at 9kts...
    And btw, when running at hull speed, retract the trim tabs all the way up and compare speeds. On the Johnson 70 I run, I gain a quarter knot with the tabs up. It s only 2.5% more speed but that s 150 gallons of diesel over the Miami - Nantucket round trip!
    Not sure what the need is to dissect every word... If you want to use the least amount of fuel over a trip, hull speed is the way to go. on most boats the engines will remain hot enough and just require a quick run to speed every day
    I usually burn about 3100 gallons for the 1500nm trip from Miami to Nantucket with the Johnson 70 (cat 3412Es) doing 95% of the trip at 10kts. At 22 kts, i d be using 6500 gallons... If the boat / owner schedule allows, it s a no brainer
  20. PacBlue
    Dana Point, Ca
    In a nominal situation, then yes.
    Not including the point when the engine is overloaded and lugged down, but that is a different topic, not related to the thread.
    There are plenty of Commercial engines built and tested at 110% overload, but sold and warrantied at the 100% rating, but this is not typically seen in yachts under 100'.
