Click for Delta
Click for Burger
Click for Bering
Click for GPlink
Click for Lurssen
Click for Dockwise
Go Back   YachtForums.Com > GENERAL YACHTING DISCUSSION > General Yachting Discussion > (Be) Prepared For The Worst
Reply
Old 06-10-2011, 08:52 AM   #1 (permalink)
Senior Member
brian eiland's Avatar
Five people aboard a 60-footer that sank in the Gulf of Alaska were rescued because the motoryacht was equipped with the proper safety and communications gear. Watch...VIDEO:
http://www.soundingspub.com/news/dis...-for-the-worst
brian eiland is offline   Reply With Quote
Old 06-10-2011, 09:03 AM   #2 (permalink)
Senior Member
PropBet's Avatar
Praise to preparation and contingency planning, training and knowing how and what to do when the situation arises. We should have more of these stories, and survivors shouldn't be 'the lucky few' but the well prepared and trained.
Thanks for posting Brian.
PropBet is offline   Reply With Quote
Old 06-10-2011, 01:30 PM   #3 (permalink)
Registered User
Excellent article. My open questions:
- Was there a reasonably low "high water alarm" to maximize the crew's ability to diagnose and remedy the problem before it was "too late to do anything"
- Did the boat allow good access to the water ingress area so that something could be done to stop the ingress
- Were the crew able to try to stuff things such as towels into the ingress area, in an attempt to lower the ingress rate to something the bilge pumps could deal with
- Did the boat have the ability to draw engine cooling water from the bilge instead of the ocean, in an attempt to dewater
- Was there a gasoline powered bilge pump that could have been used to dewater
- The waters were undoubtedly too cold to drape a tarp under the hull (hard to do without getting in the water). Nevertheless, a 30x30 tarp might be a useful thing to have aboard if in warmer waters.
- Were there not watertight compartments in the engine room, sufficient to allow the boat to remain afloat even with the engine room flooded.
Dan
dan1000 is offline   Reply With Quote
Old 06-10-2011, 04:15 PM   #4 (permalink)
Senior Member
Greetings,
Glad there were no fatalities. Interesting comment that the boat had "dripless" shaft seals.....Hmmmmmm.....
Peter.
Savasa is offline   Reply With Quote
Old 06-10-2011, 04:30 PM   #5 (permalink)
Senior Member
Marmot's Avatar
Quote:
Originally Posted by dan1000
My open questions:
Was there ...?
Did the ...?
Were the ...?
Did the ...?
Was there ...?
Were there ...?
It was a Bayliner. Not even Nordhavn can answer yes to those questions.
Marmot is offline   Reply With Quote
Old 06-28-2011, 09:22 AM   #6 (permalink)
Registered User
Soundings has a feature on this sinking and rescue in this month's print issue.
Sounds like the crew (was owner-operated, w/ experiienced boaters aboard) was well-prepared, and did things by the book.
That one could have been very bad!
meblom is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
All times are EST. The time now is 11:30 PM.
Click for Horizon
Click for Garcia
Click for Westport
Click for Llebroc
Click for Bertram
Click for Trinity
