Click for Westport Click for Glendinning Click for Ocean Alexander Click for Abeking Click for Nordhavn
Defever trawlers other budget suggestions
Discussion in 'General Yachting Discussion' started by zudnic, Jun 3, 2011.
  1. zudnic
    zudnic Senior Member
    Vancouver
    Might look at a 1986 57ft Defever trawler this weekend. I'm looking because I've set a budget and size limit being single. Purpose of the thread to see what else max 60ft and priced to a max of $500,000 is out and about. With those in mind what would you be looking at? In other words the "yachting" on a budget to get out on the water thread!
  2. Pascal
    Defevers are OK and maybe a little above the average older trawler in quality,although as usual maintenance and upkeep is just as important.
    on this kind of budget, i'd look at something like a viking or hatteras MY of the same vintage... much better built quality in my opinion. obviously the MY hull will use a little more fuel but fuel is really just a fraction of your overall budget. a little more fuel is a lot cheaper than havign to replace fuel tanks for instance (viking and hatts. have non corroding fiberglass tanks).
    All good info.
    To the OP, How do you plan on using the yacht and how much usage?
  4. zudnic
    Vancouver
    General cruising around on weekends with family mostly. But could end up being by myself. Hence the size limit.
    I also thought it would be interesting to see whats available at a realistic level. We all can't afford 80 to well over 100 footers. :D
