Click for Burger Click for JetForums Click for Walker Click for Cross Click for Ocean Alexander
Aluminum hull & composite superstructure?
Discussion in 'General Yachting Discussion' started by DDD, Jul 1, 2010.
  1. DDD
    DDD New Member
    North palm beach
    I have seen steel hull and alloy superstructure and I have seen steel hull and GRP superstructure. Has anyone ever done an alloy hull and GRP (cored) superstructure? What are the pro and cons of this?
  2. AMG
    I think Oceanfast built several yachts like this already in the 1980:s.
    http://www.oceanfast.com.au/go/history
  3. YachtForums
    I seem to recall the Delta-built 161’ Gallant Lady had an aluminum hull and composite superstructure...?
  4. DDD
    DDD New Member
    North palm beach
    I am very impressed. This is the only yacht I found with this combination. What are the advantages and disadvantages.
    The advantages mostly would be a lack of maintanence on the superstructure in regards to paintwork and paint blisters. Better sound deadening (GRP) does not transmit as much noise. Possible weight savings. I worked on that Delta for a short period of time. You don't have to deal with the dissimilar metal issue in regards to having stainless bow rails and such with SS screws into aluminum.
  6. dennismc
    dennismc Senior Member
    Vancouver BC
    aluminum and Composite construction
    One issue is two totally different rates of expansion and contraction between the two, most major fastenings today through Alu. are sleeved and through bolted, with mylar separation between teak etc and alu. The beauty of welded alu. is it don't leak !!!!!
    construction methods are critical with alu. to minimize oxidization at construction and during it's lifetime, continous welding is critical rather than spot.
  7. SandEngXp
    SandEngXp New Member
    Texas
    Composite Superstructure on Metal Hulls
    This has been done since the early 80's. Yachts and Ferries. It started as a way to take advantage of composites by traditional metal builders to mitigate risk. Today it is mostly used on very large vessels and some ferries.
    Fexas and P-J's did one of the early ones - 80 ish feet as I recall. SSM and Bay Island transport just launch a new hybrid ferry.
  8. Loren Schweizer
    Coral Gables/Ft. Laud., FL
    For many years, the U.S. Navy, and at least a couple of U.S. boatbuilders, used DetaClad, a DuPont product, to join the Al superstructure to the steel decks.
    No way for leaks to occur and no mechanical fastenings which reduced labor costs.
  9. Marmot
    Used? It's still used a lot! Ask Derecktor much they used last year. We used a lot on a local project recently.
