Click for Abeking Click for YF Listing Service Click for Burger Click for Mulder Click for Furuno
Going Through the Oil!
Discussion in 'General Yachting Discussion' started by Capt Mike, Jun 18, 2010.
  1. Capt Mike
    Capt Mike New Member
    Naples, Fl
    I have to take a boat from Tampa, Fl to Houston, Tx. Is there anything I should be concerned with regarding the Oil??
    Thank you!
  2. Marmot
    If you go swimming it will ruin your towels. Otherwise it just messes up the paint along the waterline.
    I wouldn't run the watermakers while in a slick.
  3. Jorge Lang
    Jorge Lang Senior Member
    Should there be a concern regarding the raw water that goes to the heat exchangers. From there the water may go to systems like, gear coolers, shaft seals, and the exhaust. What are the chances of the thicker oil clogging these systems?
  4. AMG
    IsnĀ“t it possible to go around the oil? I would never go near it...
  5. Fishtigua
    Fishtigua Senior Member
    Guernsey/Antigua
    We've had a warning from Volvo not to go through the oil.
    If it gets sucked up into the cooling system, especially on Gas engines, Volvo warn that the warranty may not be valid on an overheat.
    Just don't do it.
  6. Marmot
    If you are running a displacement hull the water intakes are well below any oil. If the seas are rough enough that the intakes suck surface water then the oil is going to be broken up anyway. If you are running at planing speeds then avoid the oil or slow down when crossing a slick.
    For the most part, the oil sheen on the surface is only a few molecules thick. The drifts of red mousse that you see on the news are usually long and narrow like tidal rifts, they are only a fraction of an inch thick and can be avoided entirely or passed through at 90 degrees at slow speed to avoid sucking up anything. Even that stuff is mostly water and is flushed through the heat exchangers pretty quickly.
    There is a lot of hype about oil slicks and the warnings about voided warranties are a "heads I win, tails you lose" deal for the manufacturers, they see an oil moustache on the bow and they can claim immunity from everything. Don't forget that there is a great deal of water flushing through the coolers and very little oil available to foul the tubes or plates and even a tarball is washed off the hot surfaces pretty quickly.
  7. Fishtigua
    Guernsey/Antigua
    Many of the Shrimp boats we see laying the oil booms may have a keel cooling system that is closed loop.
    Would you want to run your outboard in that goop????
  8. Marmot
    The jacket water of a heat exchanger cooled engine is a closed loop too. Not only that but the flow across the raw water side of a heat exchanger surface is many times faster than that of a keel cooler so it flushes contamination off much faster and more thoroughly.
    Why not? The stuff isn't a foot thick. Many, if not most of the near shore boom boats are outboard powered.
    Outboard motors performed very well in the thick cold crude of Prince William Sound, they will perform equally well in the thin light crude floating on the warm waters of the Gulf of Mexico.
  9. CaptTom
    CaptTom Senior Member
    Palm Beach to Ft Lauderdale
    Mike,
    Several of the boatbuilders on the Gulf I have spoken to recommend staying away from it as much as you can. A surface sheen is one thing, but the oil clumps and slicks we have been seeing can be deep and I have seen on the news were some of it is like molasses, potentially clogging intakes and such. Also, you make think the oil is just another liquid that will pass through the raw water side, but it can gum up heatexchanges and coolers, coating internal surfaces that may impede proper cooling and transfer of heat. You certainly don't want to gum up a thermostat either. And don't even think about running a fresh water maker during the travels. That can be an expensive cleanup.
    What type of vessel are you transporting? Can you run south of the spill, acroos the Gulf or do you need to run the coast?
    If you run through it and get an oil brow, will that come out of the gelcoat or Awlgrip with soap or make a permanent stain or shadow?
    Many unanswered questions, but I would stay away if possible.
  10. Capt Mike
    Naples, Fl
    It's a 42' Beneteau Trawler. I have not seen it yet, but according to the spec's I only have a range of about 150 Miles. So I can't go around south. I hate to lose another job to this, I wont take it if I think it could damage the gelcoat or mechanical systems!!
    Any more thoughts????
    Thank You
    Mike
  11. AMG
    On that boat you can probably add some bladdertanks if you like. Try to figure out how much extra fuel you would need to go south of the oil..?
  12. Marmot
    Make sure the owner knows that there is a risk of staining the gelcoat if it is not hauled and cleaned as quickly as possible after arrival.
    Put a good coat of wax along the waterline and higher on the stem to make cleaning easier after you arrive. At worst it will look like every boat on the BC coast where there is a lot of tannin in the water.
    It looks like you will be running along the beach all the way so you will have good info on the location of mousse patches so will be able to avoid them. I wouldn't worry for one moment about the mechanicals. Carry the usual spare impeller and enjoy the trip.
  13. jspiezio
    jspiezio Member
    Changes
    42 foot trawler with 150 mile range seems a bit off, are you sure of the range?
  14. K1W1
  15. Capt Mike
    Naples, Fl
    All the info I can find online puts me over 400 mile range @ 15K, I am going to look at the boat on Tues. I will get some more accurate info. south might be the right option. I wounder what the Mileage difference is......
    Thank you everybody for your help.
    Mike
  16. AMG
    Are you sure you are a yacht captain..?
  17. Marmot
    Sounds like many of them. :rolleyes:
  18. Savasa
    Savasa Senior Member
    Iqaluit, Nunavit, Canada
    Greetings,
    Get out the Shell road map...
    Peter
  19. Marmot
    It's only a few centimeters on the map. ;)
  20. dsharp
    dsharp Senior Member
    lake jackson, tx
    Going through the oil
    If the boat appears to be in good shape I would run from Tampa to Apalachicola and then down the intracoastal to Houston. I think its about 320 mile from Ft. Myers to apalachicola so you should be within your range. The 400 mile range sounds more accurate than the 150 miles originally quoted.
