Click for Abeking Click for YF Listing Service Click for YF Listing Service Click for Burger Click for Cross
Aleution Yacht's Polar Bear; Caught Fire
Discussion in 'General Yachting Discussion' started by travler, May 26, 2010.
  1. travler
    travler Senior Member
    roche harbor wa
    does any one know who designed and or built polar bear
    thanks travler
    Admin Edit: Boat brand added to thread title for better indexing
  2. RER
    RER Senior Member
    Newport Beach CA
    Aleutian... (If you're asking about the boat built in Tacoma WA in 2008)
  3. Viceroy
    Viceroy Member
    Semi-retired in Sidney, British Columbia
    As of May23, Polar Bear was moored in Victoria's inner harbour...Victoria, B.C., on Canada's wet coast! Cheers, Richard.
  4. MBY
    MBY Senior Member
    Newport Beach, CA
  5. dennismc
    dennismc Senior Member
    Vancouver BC
    Was there two Polar Bears? I saw one in Vancouver 3 yrs ago, she was all white and built in B.C. ?
  6. Dave Stranks
    Dave Stranks Member
    Coal Harbor Vancouver
    If it was the Polar Bear built by ABC yachts in North Vancouver. I have been on her "sweet boat". Use to run into it up the coast a lot
  7. 'RoundTheHorn
    'RoundTheHorn Senior Member
    Salish Sea
  8. TimL
    TimL New Member
    Puget Sound
    Polar Bear was built by Aluetian (now Citadel) Yachts in Tacoma WA in 2011. It is a big trawler yacht. You tube has some videos of her interior. It was a nice yacht. Saw it in Roche Harbor a year ago. Too bad this happened.
  9. Capt J
    Does anyone know the cause of the fire? Sad to say it, but she's unrepairable and just a memory at this point. It's a good thing that it happened where it did and doesn't look like any lives or other vessels were endangered.
  10. NEO56
    NEO56 Member
    Miami
    There was a story on Dockwalk today, supposedly there was some welding being done below decks, the cops had to shoot out the windows so they could get more water into the boat.
  11. Capt Ralph
    Crazy.
    She was just used as an example in another thread. Of course I fell in love with her. Now, Next day she's gone.
    Bummer.
    Only heard of two injured. Sorry for them but glad nobody more.
  12. Delfin
    Delfin Member
    Anacortes, WA
    I believe you will find it is Citadel Yachts.
    Motor Yacht POLAR BEAR - a Citadel Superyacht
  13. olderboater
    They were Aleutian however until they changed their brand name. I think the parent company even kept the Aleutian name, but it was causing confusion as a brand.
  14. Delfin
    Delfin Member
    Anacortes, WA
    Ah so, thank you.
  15. arion
    arion New Member
    Manchester
  16. milo12
    milo12 Member
    Morro Bay CA
    Nice video, thanks.
    Does anyone know why all the fire fighters were just standing around? I get the fire was too big to put out but in other large fires I have seen them pouring water on the fire anyway.
  17. Seafarer
    Seafarer Senior Member
    Hudson River
    Pouring the required volume of water onto a diesel-fueled fire will not end well for the yard, the firefighters, or the open water nearby. Can't get foam in to the source of the fire, so protect the exposures and limit collateral damage.
    Judgement call. What's at risk, and what's being saved.
  18. K1W1
    Throwing a lot of water onto burning fuel is just like throwing water into a pan of boiling oil. The resultant eruption will be something to avoid and not something you should try at home folks.
    Floating foam over the burning fluid is the only reasonably safe way to deal with and break the fire triangle.
  19. Chasm
    Chasm Senior Member
    Potential problems with diesel fuel aside it's the above.
    There is quite a bit of distance to other yachts and buildings. Most importantly, no lives were at risk.
    If assets were closer an option would be to deploy a hydroshield (Aka water curtain. Depending on water pressure the arc is typically up to 30m wide at the base and 10m high at the center.)
    Then there is of course the need to watch for the effects of sparks and embers downwind.
    The lesson here is that any fire on a yacht is a real problem. There is only very little time to do anything about it, so hit it with everything you have. Don't forget that you'll also need time to evacuate.
  20. YachtForums
    Sometimes good things come from bad situations. Case in point... it's good to see SeaFarer again! Welcome back!
