Click for Ocean Alexander Click for JetForums Click for Cross Privacy Matters Click for Ocean Alexander
Titanic: Made out of paper-maiche
Discussion in 'General Yachting Discussion' started by alloyed2sea, Oct 6, 2008.
  1. alloyed2sea
    alloyed2sea Moderator
    Alex, VA
    All along, the shipbuilders knew the hull was weak.
    "It was a matter of keeping the customer happy," says Brad Matsen, author of the new book "Titanic's Last Secrets." and leader of a team of divers and scientists who found two large sections of the ship's bottom in 2005—enough for forensic scientists to determine that the flimsy hull and skimpy rivets were, in fact, responsible for the ship's fate.
    "If J. P. Morgan wanted a boat made out of papier-mâché, they would have made him a boat out of papier-mâché."
    When Tom McCluskie, a retired Harland and Wolf archivist, got wind of Matsen's findings, he forked over details of the company's 1912 investigation, which had been hidden until then. "What we figured by doing forensic analysis on the extra pieces of hull matched exactly with what Harland and Wolff calculated based on their detailed knowledge of the ship's construction," says Matsen. "McCluskie said he had been waiting for someone to piece it together before he turned the documents over."
    Who writes this stuff? :(
    http://www.newsweek.com/id/162267
  2. Loren Schweizer
    Coral Gables/Ft. Laud., FL
    So, what was the hull plate thickness where the ice scragged it?
  3. alloyed2sea
    Alex, VA
  4. alloyed2sea
    Alex, VA
    "Big Piece"
    The "Big Piece" came from the starboard side of C-Deck, most likely covering First-Class cabin C-83 and cabin C-85.
    Heck, you can even buy a "Lucky Watch" made out of the stuff:
    http://hubpages.com/hub/Watches_Made_from_Titanics_Hull_Sell_for_150_000
    Note:
    A metallurgical analysis of steel taken from the hull of the Titanic's wreckage reveals that it had a high ductile-brittle transition temperature, making it unsuitable for service at low temperatures; at the time of the collision, the temperature of the sea water was -2�C.
    The analysis also shows, however, that the steel used was probably the best plain carbon ship plate available at the time of the ship's construction.
  5. NYCAP123
    alloyed2 sea,
    You have a good sense of humur. Good choice in the avatar.
  6. Castlerock
    Castlerock Senior Member
    New England
    Nice watches but totally useless:
    "Romain Jerome has released a line of watches, called TITANIC-DNA, that are actually made from pieces of the Titanic. Here’s the rub: you can’t wear them. If they’re exposed to air they’ll begin to rust and fall apart. The only way to own one is to keep it in an argon-filled cylinder."
  7. Codger
    Codger YF Wisdom Dept.
    Western Canada
    Interesting. So, for the sake of some badly chosen high sulphur steel, a group of unfortunates died and countless men have had to politely sit through a movie that they'd rather not have had to see.
