Click for Burger Click for Westport Click for Walker Privacy Matters Click for Burger
Explain Trawler vs Motor Yacht Please...
Discussion in 'General Trawler Discussion' started by Mets, Sep 12, 2007.
  1. Mets
    Mets New Member
    Miami Beach, FL
    Sorry if this is a dumb question, but could somebody explain what exactly defines a trawler and what exactly defines a motor yacht? I've always just thought of trawlers as slow house-like boats, but I don't think that is correct.
    How did this come up? I recently saw the Calixas 105, which is called a yacht on their website but a trawler on this forum, so I started questioning my self-made definition. Then I see Mochi Craft is listed as a trawler, and they seem to have a range under 300 nautical miles, and they look like a sleek cruiser. Now I'm just confused :confused:
  2. KCook
    KCook Senior Member
    Phoenix
    You are perfectly right. There is a grey area. And that grey seems to be coming bigger every year! But a Mochi is not my idea of a trawler at all.
    Kelly Cook
    Nordhavn is though. You should check out them as well as some of the others in our Trawler brand section. You can see one of my writeups on the Nordhavn 86'
    http://www.yachtforums.com/forums/nordhavn-yacht/7426-nordhavn-86-a.html
    Take a look at the exterior, the shape, hull form, arrangement and so on and compare it to a motoryacht. I mean these are just physical differences.
  4. Mets
    Mets New Member
    Miami Beach, FL
    I guess I was more right than wrong. I still don't understand at all how Mochi Craft is a trawler, but I guess Kelly is right, I think the line is being blured. The Calixas looks more like a motor yacht than a Noordhavn.
  5. Codger
    Codger YF Wisdom Dept.
    Western Canada
  6. KCook
    KCook Senior Member
    Phoenix
    Or maybe not. To me it carries too much sail. So I would classify it as a motorsailor.
    Kelly
  7. Mets
    Mets New Member
    Miami Beach, FL
    [​IMG]
    I'm seasick just looking at them from here :p
  8. 'RoundTheHorn
    'RoundTheHorn Senior Member
    Salish Sea
    Troller not Trawler
    Actually, George Buehler coined the term troller yacht for his Diesel Duck designs after modeling them on West Coast salmon trollers. He clearly prefers the term troller when referring to his boats. Chapter 3 of his book, "The Troller Yacht Book", explains the origins of his designs.
  9. JWY
    JWY Senior Member
    Without defining or differentiating the technical terms and formulas and disregarding any reference to fishing boats, there are several terms commonly used in regards to the yachting market.
    IMHO, in general a trawler is a subcategory of Powerboat or Motoryacht and refers to a full displacement hull which usually has a maximum speed around 9 knots and carries sufficient fuel for long passages. There are semi-displacement hulls that have speeds in the range of 12-16 knots that I (with reluctance in using the oxymoron) call "Fast Trawlers" and while they don't have transoceanic range, they usually have engines and fuel capacity to go some reasonable distance without re-fuel.
    While single or twin engines, hard chines, round bottoms, bilge keels, stabilizing sail, or flopper-stoppers, can differentiate manufacturers or their models, practical trawler attributes such as Portuguese bridge, forward sloping windows, and high freeboard frequently give boats the appearance that endears them to the trawler nomenclature.
    Trawlers that go overboard (NPI) on amenities and grandiosity sometime deserve the label of Trawleryacht. Those that promote exceptional range or are capable of self-sufficiency in remote locales, use the newish term Expedition Yacht.
    Judy
