Click for Ocean Alexander Click for Delta Click for Walker Click for Northern Lights Click for Burger
Legacy on the Hard
Discussion in 'General Sailing Discussion' started by Windifferent, Nov 18, 2005.
  1. Windifferent
    Windifferent New Member
    NY/LIS
    Found this picture on another forum but little info. Apparently the SY Legacy (Perini Navi) caught in hurricane Wilma stranded in the FL Keys several hundred yards from deep water and with a destroyed rig. Has anyone heard anything about this. Am deeply curious to know whether and how they have/will get this boat off the sand.
  2. hlbeckley
    hlbeckley New Member
    Johannesburg
  3. Kevin
    One question about the pic... where's the keel? :confused:
  4. Windifferent
    NY/LIS
    Interesting Article
    HLBeckley,
    Thanks for that interesting link. As you say, sensational.
    Kevin,
    I assume that the boat is a centerboard vessel but one would presume that some part of the keel housing is buried in the sand.
  5. Kevin
    Buried, and sucked in. :eek: Ouch.
  6. KCook
    KCook Senior Member
    Phoenix
    Ok. Speaking as a total amateur :p , I would stabilize it by surrounding it with floation bags. Then inject high pressure water under the hull to break it free. Then tow out to deeper water. Then recover with a conventional barge and crane(s).
    Not a pretty sight,
    Kelly
  7. Kevin
    I checked out the Perini Navi site, and I don't see any info about what the bottom of Legacy looks like... fin keel, centerboard, etc. Either way, there's a hefty (and heavy) chunk of yacht buried in what is evidently very soft sand.
  8. YachtForums
    That would be a solution *IF*... she wasn't several hundred yards away from deep water. It was the storm surge that carried her into the flats. Can't duplicate that by other means. A full-moon, high tide might help, but it's doubtful the keel could be raised above the reef's sub-surface level.
    Anyone else have an idea? CH-47 Chinook? Sikorsky Skycrane? Probably not. Dredge a path?
  9. Kevin
    CH-47 Max Payload: 10,000 pounds
    Skycrane Max Payload: 20,000 pounds
    We're still short.
  10. KCook
    KCook Senior Member
    Phoenix
    One way to avoid dredging a trench for the keel would be to let the yacht flop over on one side. Then drag it across while still laying on it's side. As I said, not a pretty sight.
    Kelly
  11. Ben
    Ben Senior Member
    Melbourne Australia
    I'm thinking shaped charge, rocket sled, and tonnes of vasaline.
    I'd have it out in a jiffy.
  12. MedRascal
    MedRascal Senior Member
    Monte-Carlo, Monaco
    Any more info on how they will save "Legacy" ?
    Do you think that the shipyard could get involved to salvage one of thier "creatures" ?
  13. AMG
    This would be a piece of cake. Just put out some steelramps to land a sublift on. Ferry and drive it to the boat, lift her gradually in the sublift and drive her back to deep water...
    Maybe there are no such high capacity sublifts available yet, but it can not be too hard to build within a month or two...?
    Here are PDF-drawings on a 300-tonnes from Anytec in Sweden.
    http://www.anytec.se/filarkiv/GA-1300.pdf
  14. sailronin
    sailronin Senior Member
    North Palm Beach, Fl.
    Call Resolve!
    Bet they already have.
    Perini's generally are a keel-centerboard arrangement.
    Dave
  15. Windifferent
    NY/LIS
    Salvage
    No way to float/move Legacy without destroying even more of the 'marine sanctuary' with endangered/protected wildlife and coral... No way the environmentalist and govt agencies will allow..
    Checking details on sisterships which have been listed for sale, estimate the displacement around 1MM pounds...
  16. Kevin
    Any developments on this yacht? I was just reading about the cargo ship in Ensenada that they finally got floating, and remembered this thread. Any news?
  17. Kevin
    Found this:
    [​IMG]
  18. MedRascal
    Monte-Carlo, Monaco
    Is this article you found dated?
  19. MedRascal
    Monte-Carlo, Monaco
    Thanks!
    This means that the boat at least as of March 2006 was still sitting there ... :(
