Click for MCC
Click for Platinum
Click for Lurssen
Click for Oceanco
Click For Affinity
Click for Westport
Go Back   YachtForums.Com > YACHT & BOAT FORUMS > Sailing Yachts > General Sailing Discussion > The Next America's Cup in Multihulls
Reply
Old 10-19-2009, 07:24 PM   #46
84far
Registered User
84far's Avatar
to bad the America's Cup has become a fast, the boats are unreal!
84far is offline   Reply With Quote
Old 10-27-2009, 11:34 PM   #47
84far
Registered User
84far's Avatar
hi all, ive found more news on the RAK regatta, and Alinghi will appeal this.
A New York judge has ruled that Ras al-Khaimah, United Arab Emirates, cannot host the America's Cup based on the 19th-century document that governs sailing's marquee regatta.
The ruling by Justice Shirley Kornreich of the New York State Supreme Court is a blow to two-time defending champion Alinghi of Switzerland. The Swiss picked the Persian Gulf for their February showdown against American challenger BMW Oracle Racing.
Kornreich said her decision was based on the stipulation in the Deed of Gift that the America's Cup cannot be sailed in the Northern Hemisphere between Nov. 1 and May 1, not on concerns by the Americans that RAK was unsafe due to its proximity to Iran
far
Old 11-10-2009, 07:43 PM   #48
Garry Hartshorn
Senior Member
Garry Hartshorn's Avatar
Location: I have an old homestead about 3 hours drive west of Sydney but I am hardly ever there
A friend just sent me these photo's so I thought I would share
__________________
www.pro-yacht-captain.com
Garry Hartshorn is online now   Reply With Quote
Old 11-10-2009, 08:04 PM   #49
YachtForums
Publisher/Admin
YachtForums's Avatar
Quote:
Glad you did. Not something you see everyday... a heli lifting a hull. Or two!
Old 11-10-2009, 08:19 PM   #50
Garry Hartshorn
Senior Member
And a few more
__________________
Old 11-10-2009, 08:22 PM   #51
YachtForums
Publisher/Admin
There exists an ultimate irony in these pics, but it's not coming to me. New meaning to flying a cat?
Old 11-10-2009, 11:07 PM   #52
84far
Registered User
84far's Avatar
isnt it odd that the rig just happen to fall down the other day... and now there have replace it with the wing fast.... something's fishie .
also does anyone know anything more about the ACC coming to QLD AUS?
far
Old 11-11-2009, 04:57 AM   #53
K1W1
Senior Member
K1W1's Avatar
Quote:
Originally Posted by 84far
also does anyone know anything more about the ACC coming to QLD AUS?far
I think that Valencia has been proposed as a race venue and the GGYC have until Friday to say ya or na.
__________________
Cheers,
K1W1
K1W1 is offline   Reply With Quote
Old 11-11-2009, 07:49 AM   #54
Kevin
YF Moderator
Kevin's Avatar
Exactly K1W1, that's what's on the table as of right now.
Alinghi's plan to use Ras Al Khaimah, UAE was flat out rejected by the New York Supreme Court. They subseuently went back to the original plan of racing in Valencia in February (which is contrary to the Deed Of Gift) and proposed two alternative Southern Hemisphere venues: Proserpine/Airlie Beach and Townsville in Australia should GGYC and BMW Oracle want that. The deadline for making the decision is this Friday.
Kevin is offline   Reply With Quote
Old 11-11-2009, 10:27 AM   #55
brian eiland
Senior Member
brian eiland's Avatar
Wingmast/Wingsails
* Steve Clark gives an expert view on BOR90's America's Cup wingmast
Steve Clark is widely acknowledged as one of the most astute and most experienced inshore multihull technologists and sailors on the planet. Sail-World asked Steve Clark for his analysis of the largest wing mast ever built.
Steve Clark:' The rig on BOR90 is a two element single slotted wing. This is a 'cleaner' configuration instead of a 'more powerful' configuration. You will not get the high lift coefficients without the #2 element ( the flap in the slot that directs the flow through the slot.) This is probably not a big deal because they have the ability to set head sails for down wind work.
'It may or may not have twist capabilities. For one thing, the use of head sails makes this less necessary. For another, the majority of the wind gradient is in the first 30' off the deck, so given the scale of this wing, it may not be as big a deal as it is for the smaller C Class wings.
'The control system seems to be the tried and true Patient Lady (the predecessor to Cogito) system, which is self tacking and very well worked out.
'The ability of the wing to operate at low angles of attack will be a big step forward for these boats which operate with so much apparent wind. I think it's going to help. If it blows hard enough for them to fly the main hull without the a jib being set, they will be faster upwind without the jib. This was true of Stars and Stripes 88 and should be true here given that this is a very clean wing. Stated another way, this rig will be able to sail longer without being backwinded by the jib. If that becomes a problem, the boat will be faster without the jib...
The entire interview by Richard Gladwell in Sail-World.com:
www.sail-world.com
...then have a look at the size of this crewman up in the rigging....WOW!
brian eiland is offline   Reply With Quote
Old 11-11-2009, 10:47 AM   #56
brian eiland
Senior Member
America's Cup: Steve Clark on Bows, Stress and Weight
Here are some other good observations:
http://www.sail-world.com/NZ/America...d-Weight/58754
...and note this endorsment
Despite having his skipper and lead designer, Duncan MacLane, from the Cogito project, consulting to Alinghi, Clark can only guess at the development process the America's Cup Defenders have worked through with the multihull now known as Alinghi 5.
'I'm pretty sure that a bunch of the sailing Le Black did over the last year, was loaded to the gills with strain gauges as Dirk Kramers refined their understanding of how the various components of the struts and strings are loaded', Clark surmises.
'I also suspect they tried several different configurations of trussing to determine if there was a better plan. I have a great deal of admiration for Dirk and would hang my ass out a 10th story window on a piece he said was strong enough! So I would probably believe the platform is not going to see the kind of failures Team Phillips and others have seen.'
Old 11-11-2009, 11:07 AM   #57
brian eiland
Senior Member
ORACLE Racing: An amazing 24hrs, video presentation
http://www.youtube.com/watch?v=dySXmkAEy1A
Old 11-12-2009, 05:20 AM   #58
84far
Registered User
84far's Avatar
thanks K1W1!
to have it in australia i think would not be a bright idea, the acc has been away from our shores for to long. i think back in spain would have to be the right one. enjoy another pic... its just... WOW!
Old 11-12-2009, 05:25 AM   #59
84far
Registered User
84far's Avatar
also... have BMW changed there centre boards on the outer hulls? they were curved, and now look straight.... comments
far
Old 11-12-2009, 09:46 AM   #60
K1W1
Senior Member
K1W1's Avatar
Quote:
Having spent a couple of years in Townsville working around the waterfront scene I can't imagine a less prepared place for this type of traveling circus.
__________________
Cheers,
K1W1
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
All times are EST. The time now is 11:34 PM.
Click for Lurssen
Click for Christensen
Click for Sea Spirit
Click for Horizon
Click for Quantum
