Click for Ocean Alexander Click for Abeking Click for Ocean Alexander Click for Glendinning Privacy Matters
Sail Loading on the Rig, Rig Loading on the Vessel
Discussion in 'General Sailing Discussion' started by brian eiland, May 29, 2009.
  1. brian eiland
    brian eiland Senior Member
    St Augustine, Fl and Thailand
    ...this thread is a bit of an excerpt from an extensive subject matter I addressed elsewhere. Thought some might enjoy seeing some hi-tech hot rods sailing over in Europe
    The "SYZ & CO" is a revolutionary hydrofoil catamaran which could become the fastest multihull on Lake Geneva with a view to both beating Lake Geneva speed records and winning its main races, most notably the Bol d’Or Mirabaud.
    The hydrofoils are lifting foils placed under the hulls which allow them to rise so that only the foils remain in contact with the water. This substantially reduces the drag in the water, allowing the yacht to achieve far greater speeds than traditional boats.
    Contrary to other prototypes which aim solely to beat records in very specific wind speeds, wind angles and wave conditions, the "SYZ & CO" hydrofoil catamaran aims to win races. As a consequence, she must be able to sail fast in all situations.
    http://www.syzfoiler.com/projet/concept/index.lbl
    ..and look closely at the longitudanal supporting structure to maintain rig
    tension
    ..... http://www.syzfoiler.com/images/photo/index.lbl ..look under 3D VIEW
  2. brian eiland
    Boat with NO HULL
    The 2009 version of the Mirabaud LX, Thomas Jundt’s foiler has a new hull that favours speed and stability by light wind. Its mast has also been reinforced in order to improve the upwind sailing angle, as well as the reactivity of the boat. Finally, the sensors used to trim the foiler’s flaps have been improved, allowing a better precision whilst sailing. Introduced in 2008 as “the boat with no hull”, the Mirabaud LX has recently proved that this wording could be translated into reality by sailing on its hydrofoils with no buoyancy at all. Thomas Jundt and his team have accomplished this challenge and validated a different and creative way to consider the sport of sailing.
    ...and check out this YouTube Presentation
    http://www.youtube.com/watch?v=Lx6K1PzqnG0
