Click for Mulder Click for Perko Click for YF Listing Service Click for Abeking Click for Ocean Alexander
Yacht Draft in the Caribbean
Discussion in 'General Yachting Discussion' started by Scotty193, Mar 13, 2008.
  1. Scotty193
    Scotty193 New Member
    Kansas
    Hey everyone, I was wondering if anyone had any advice or information on what yachts are good to use in the Caribbean. I have read many reviews and some mention having a shallow draft in order to navigate the Caribbean. How shallow are they talking, 3 ft or 10 ft etc. I am very new to yachts and I live about as far away from the ocean as possible (Kansas, US), but it's fun to dream :) I hope I am posting this in the right place. Thanks for your help and great forum.
  2. nas130
    nas130 Member
    florida
    Scotty,
    Welcome to the forum. You will find many people here offering great advice about many different aspects of boat ownership, charter, etc...
    There is no set rule for drafts in the Caribbean. Different ports have different depths.
    The Bahamas maximum is around 8 feet. The major ports are deeper, but the desirable "out" islands are much shallower.
    Best Regards,
    Nicholas
    Port St. Charles Marina here in Barbados is 14 feet at Low Tide.
    http://portstcharles.com/display.php?page=2
    I am not sure of the depth of the Yacht Haven Grande in St. Thomas, USVI but it has to be significantly deep since it accomodates Rising Sun regularly.
    http://www.yachthavengrande.com
    Isle De Sol in Simpson Bay St. Maarten is another very good marina with maximum draught of about 20 feet.
    http://www.igy-isledesol.com/marina/overview/
    Falmouth Marina in Antigua also has draught of up to 20 feet and could accomodate yachts up to 330 feet long.
    http://www.antigua-marina.com/
    Atlantis Marina, part of the Atlantis hotel in Paradise Island, Bahamas has excellent conditions with 12 foot draught at low tide.
    http://www.atlantis.com/resources/marina/specifications.aspx
    The small Clarkes Court Bay Marina in Grenada
    http://www.clarkescourtbaymarina.com/
    Also there is the bigger and more sophisticated Port Louis Marina still underconstruction in Grenada. It has accepted the Maltese Falcon and other large yachts. The marina has varying depths but up to 26 feet are attainable.
    http://portlouisgrenada.com/port-louis/real-estate/port-louis-site-plan.html
    Rodney Bay marina in St. Lucia has beautiful facilities with draught of about 14 feet.
    http://www.igy-rodneybay.com/marina/
    Ocean World Marina in Dominican Republic has draught of up to 12 feet.
    https://www.marinamate.com/m-cb-dr.html
    Errol Flynn Marina in Port Antonio, Jamaica has draught up to 30 feet.
    http://www.portbooker.com/en/marinas/jamaica/port-antonio/port-antonio/errol-flynn-marina-and-boatyard/
    Village Cay Marina in Tortola BVI has up to 11 feet.
    http://www.igy-villagecay.com/marina/overview/
    So no need really to worry about the draught of your yacht.
  4. Scotty193
    Kansas
    Thanks alot for the information. I've been reading alot of the threads trying to gather as much information as I can about owning a yacht. It is a little overwhelming at times because there is so much more involved than just taking a runabout out on the lake for a day.
  5. wadadli
    wadadli Senior Member
    Antigua, Antigua & Barbuda
    let me give some more accurate details as to where Antigua is concerned.
    the channel going into falmouth harbour is 30ft deep
    Falmouth Harbour Marina
    depth; 21ft
    capability; it can accomodate yachts in excess of 380ft. ( the 377ft. le grand bleu docked there on numerous occasions)
    the main dock is 380ft. long, while the secondary piers are 338, 335, and 244ft long.
    Antigua Yacht Club Marina
    depth; can accomodate yachts with draft in excess of 25ft.
    capacity it is capable of accomodating mega yachts. notable yachts which docked there were( maltese falcon,nero, athena, eos, tatoosh, limitless and pelorus)
    the longest pier is 290ft in length
  6. wadadli
    visual aid
    [​IMG]
    [​IMG]
  7. NYCAP123
    In general you'll find that most motor yachts up to 50' or so will have a draft of under 4'. Up to about 80' it's about 5' to 6'. Above that 7' to 11' until you get real big and above 80' (and often below) you'll generally find them carrying a dink or tender which will allow the yacht to anchor out and still come in. So draft isn't usually as important as prudence.
    In reality Scotty's area is much harder to navigate as lakes will often have old 20' trees sticking up from the bottom of 21' deep lakes after the spring thaws and rains. Getting local knowledge there is key as it is when transiting questionable areas anywhere in the world. When in doubt follow someone bigger than you or put out a call for local knowledge. Otherwise dead slow.
  8. Manny
    Manny Senior Member
    Puerto Rico
    In the caribbean, you need a boat with 2 things:
    a draft shallower than 10 ft and a sea-worthy boat that can withstand rough seas
    I live here, and my 54 bertram couldnt be a more perfect boat thatll meet these 2 conditions. but if you want a motoryacht, I coldnt say. I dont know much about motoryachts.
  9. Yacht News
    Draught shouldn't be a problem in the Caribbean unless you own something bigger than "Rising Sun" or one that draws water like a cruiseship. If so then you will definitely need to berth at a commercial harbour or anchor offshore.
  10. NYCAP123
    You might want to add a 3rd...Someone maintaining a careful watch as evidenced by a certain Sea Ray in another thread.:cool:
  11. K1W1
    Isa that Bertram of your one of the rare ones with sails instead of main engines, thereby making it a sailing yacht not a motor yacht?
  12. NYCAP123
    Come on K1W1. You know SF's don't consider themselves yachts. Yachts require a blue blazer and yachtie cap.:D
  13. wadadli
    well i know Antigua definitely doesn't have a problem where draft is concerned.
    but what abt yachts like eos, athena, maltese falcon and mirabella V? don't they have deep draughts?
  14. NYCAP123
    Boats like these stick pretty close to shipping lanes, and only go into more major ports. If they want to gunk hole they'll anchor out and use their launches (which generally aren't too shabby).
  15. wadadli
    well all these yachts have docked in our marina already. :)
    and the maltese falcon docked in grenada's new marina too
  16. Manny
    Manny Senior Member
    Puerto Rico
    Kiwi Im sure you know what Im talking about:rolleyes:
    Im just saying I dont know much about motoryachts regarding sea-keeping abilities, and I mean those MOTORYACHTS, not sportfish.:D
    well, if you're all restricting the area of the caribbean to the lesser antilles, then you shouldnt have a draft problem with the exception of guadaloupe. but as far as Puerto Rico, the islands of Culebra and Vieques, and the Virgin Islands, shallow drafts are a must.
  17. NYCAP123
    Maltese Falcon has a draft of 36'10". From what I see on that chart I'm sure they come in at high tide, with great care and probably a local pilot. Remember, the charted depths are at mean lower low water.
  18. wadadli
    yes that is the draft given on yacht spotter, but i doubt the draft is that deep.....because not even a cruise ship has such significant draught.
  19. NYCAP123
    DK about cruise ships although I'd say it's close, but I remember the skipper of the Kennedy telling me they had a 47' draft. These numbers seem wild to a small boat captain like me, but they're real. Maltese Falcon has some tall masts and a lot of sail to counter so I'd believe the numbers.
  20. K1W1
    I think that is with the board down not up as it would normally be for docking.
