Click for Walker Click for Burger Click for Cross Click for Northern Lights Click for Ocean Alexander
Which Yacht?
Discussion in 'General Yachting Discussion' started by HRK, Jan 29, 2005.
  1. HRK
    HRK New Member
    OCR
    Looking for info on Lazzara, Ferretti and Azimut 68
    Considering buying a 68 fly-bridge. Looking for any info on Lazzara, Ferretti and Azimut. The good and/or bad. Thanks.
    HRK,
    There's a review of the Lazzara 68-S on the front page of YachtForums. Just follow the "Read More" link. This boat is so new that I doubt anyone will have first hand experience yet. On the Azimut 68, one of our members, John B., has owned one for two years and loves it. If you Private Message him, he can tell you everything you want to know. Here's his User Profile link...
    http://www.yachtforums.com/forums/member.php?userid=213
    Good luck!
  3. HRK
    HRK New Member
    OCR
    I read the review. How do we decide between these fine boats? You never get the negative stuff from reviews.
  4. YachtForums
    I can’t make any recommendations on the Ferretti, as you did not mention a particular model, however I can point out some attributes about the Lazzara 68-S and the Azimut 68 Plus, that would make a deciding difference in my opinion…
    On the Azimut 68-Plus…
    The main salon on the Azimut is completely open and multi level. Grouping the salon, dinette, bridge and galley together in to one room basically partitions it, but this room becomes very busy and it would be a hassle to transverse this area on a daily basis, because it is not on the same level. However, this does give the interior a very dimensional appeal.
    My biggest gripe with the Azimut is the galley… or lack thereof. It is really not much larger than a standard wet-bar on most yachts. The galley is always a popular place for guests and family to congregate, but there is not adequate room for this either.
    On the Lazzara 68-S…
    The salon interior is not quite as "curvy" as the Azimut, however it is MUCH more spacious and everything is on the SAME level, including the salon, a full size forward galley, dinette and the wheelhouse, that provides a generous area for everyone to come together, whether it be for dining, food preparation or telling the captain how to steer the boat. Another feature that I REALLY like on the Lazzara is a built-in, dedicated office below deck. This is MUST on any boat for me and few full size yachts offer this accommodation.
    Probably one of the most pronounced differences between the boats and one that is absolutely mandatory (again, this is a personal opinion), is the hard covered flybridge on the Lazzara. It is a very large, seamless addition that compliments the 68-S quite nicely adding protection and giving the boat a unique signature.
    And the last thing that comes to mind is Lazzara’s aft tender garage. Actually, this boat accommodates two tenders; one in the garage and the other on the flybridge aft deck. This gives you a choice of water toys on demand... with the push of a button for the garage stowed tender!
    From a technical and maintenance perspective, one feature I really like is Lazzara’s Seacheck program, wherein engineers do annual surveys of all operating data and compare them to each yacht’s operating efficiency. The Integrated Shipboard Information System, or ISIS, is a computerized program that monitors a 64-point check of engines, pumps, stabilizers, etc., and logs the data similar to an airplane “black box” to trace prior functions. Data from each yacht is downloaded directly to the yard, where it is checked every week by on-staff technicians to catch potential problems.
    Both of these yachts are extremely popular in the market and choosing between them may come down to personal taste… and cutting the best deal you can.
  5. HRK
    HRK New Member
    OCR
    I agree with all your points. Which boat has the best quality both in and out? Which boat handles better? Which company has better reputation, customer support and loyalty? Easier to work with? Are the Lazzara custom built and can we modify the furnishings...? What do you think of the guest rooms layout?
    What is the bottom line price on the Lazzara ( list is $2.8 mil). Which one will retain better value, say in 5 years?
  6. AMG
    As Carl is saying, your personal taste is probably more important since these yachts have different styling both in the exterior and interior.
    The Ferretti 680 are more like the Azimut, but if you go up in size to the Ferretti 731, you will find a more updated design theme that I personally like better. Also an enclosed galley and those oversized portlights in the owners cabin which is a coming trend.
    Whatever you will go for, this is a very nice size that you can handle yourself and also with access to most marinas and cruising grounds.
  7. HRK
    HRK New Member
    OCR
    We like the Ferretti 731 A LOT but it's much more $$
  8. YachtForums
    Both of these manufacturers produce yachts that are recognized for quality. The fit, finish and engineering is excellent. Really.
    I have not sea-trialed either of the boats, but generally I can give you a pretty good idea by examining the hull, propulsion, weight and CG.
    The Azimut is a 41 ton boat with a 17 degree deadrise hull...
    The Lazzara is a 46 ton boat with 12.5 degree deadrise hull...
    Both are rated with similar horsepower (Azimut=2x 1150 and Lazzara=2x 1015)
    Azimut states a top speed of 32 knots with a 29 knot cruise. I don't have performance figures for Lazzara, but you can expect them to be similar, and possibly faster for the Lazzara.
    The shallower deadrise of Lazzara's hull would indicate a top speed & cruising performance edge, but this is offest by slightly increased weight. The shallower hull will also offer greater stability, as well as reduced draft for shallow waters. Azimut's deeper deadrise should provide a smoother ride in rougher water, but it may not be as stabile and it will have greater draft. Both are equipped with thusters and equally easy to move about on for lines & fenders, so docking will not be a challenge.
    Short of having hull drawings (I haven't seen either one of these boats out of the water), it would be difficult at best to judge performance. PLEASE... keep in mind, this is just a comparison of numbers and should not be taken as an authoratative answer. We're just juggling theoretical considerations.
    Having never owned either one of these boats, I can't answer this. I can tell you that Dick and Brad Lazzara are involved in every aspect of their organization, with an emphasis on customer support. On the flip-side, Azimut has a worldwide dealer network with a lot of product & support in the marketplace.
    Lazzara's are semi-custom in nature. Many of the interior furnishings are appointed by the owner. I'm not sure on Azimut. Better check with them first. As for the guest rooms... you'll have to ask your guests. ;)
    Tough question. You might begin by evaluating the used boat market, with listing services such as YachtWorld, YachtCouncil, etc. Compare the original selling prices of previous offerings with the asking prices today.
    Do your "due diligence"... ;)
  9. nilo
    nilo Senior Member
    Istanbul
    i own a ferretti 68 for the last 3 years. i have also looked into aizmut 68 during the purchase process and actually have owned a azimut 40 some time ago.
    ferretti 68 was the first boat in the present change of design of ferretti boats. i have liked the design while my ferretti 53 was being built and the first 68 was built next to her for norberto ferretti. there are several very practical design elements incorporated into this boat. to name a few, she has good size full beam master cabin and a nice vip. both the fly bridge and the cockpit is good areas for outside dinning. she is extremely good sea, boat very easy to handle. compared to azimut a class higher on quality, especially technically.
    if you have any further specific topics to discuss pls feel free to ask them.
  10. HRK
    HRK New Member
    OCR
    ferretti 68
    It seems that Azimut is keeping up with the latest trends in interior designs better than Ferretti. I also understand that Ferretti is a very wet ride. The Lazzara seems to be built like a much bigger yacht, the galley is great but we prefer the exterior lines of Azimut and Ferretti. TOUGH choice. I am Going to Miami boat show and hoping to do sea trials in March.
  11. lwrandall
    lwrandall senior member
    Baltimore
    My 2 cents on this topic.
    I am also very impressed with Lazzaras quality and engineering. This is the size boat I have been looking at for sometime. The one thing that always bothers me with Lazzara is the lack of wood trim in the interiors. If you look at the walls and bulkheads in the Lazzaras you will notice alot of it is fabric verses the Italian and Hatteras for that matter are mostly wood ( look at the photos of the staterooms in the Lazzara 68 review). Fabric doesn't seem as warm and inviting as wood. To me, for the price of the Lazzara, which is comparable to the Hatteras and Ferretti but more than the Azimut, I would expect more wood use. However, I understand Lazzara does this to aid in the ability for future owners to change decor. I realize these are cosmetic differences not engineering differences, but most of the high quality euro yachts excell in their use of wood in the interiors I just wish Lazzara would use more to show off the skill of their craftspeople.
  12. T.K.
    T.K. Senior Member
    Cairo - Egypt
    Why don't you have a look at the Fairline Squadron 68.
    http://www.************/#/squadron/s68/
    I currently have a Fairline Phantom 48 and I am receiving next January a Fairline Squadron 78. I think Fairline make great boats with excellent hulls, very spacious and beautiful interiors with exellent workmanship.
