Click for Dockwise
Click for NorthCoast
Click for Heesen
Click for Broward
Click for Nautical Structures
Click for Burger
Go Back   YachtForums.Com > YACHT & BOAT FORUMS > Motor Yachts > Fairline Yacht > My new Fairline Squadron 78 in the build
Reply
Old 06-09-2008, 04:39 PM   #136
FISHTIGUA
Senior Member
Tarek,
I hope its a bit neater that the Sunseeker platform system. On their's there is so much ironmongery, rods and levers hanging out; if you pressed the 'Down' button a bit harder you would have a great stern anchor built-in.
__________________
Fish happens!
FISHTIGUA is offline   Reply With Quote
Old 06-09-2008, 07:09 PM   #137
PropBet
Senior Member
PropBet's Avatar
Quote:
Originally Posted by TK-F430
Hi PB,
It's a hydraulic swim platform and it's standard on the Squadron 78. It is longer than typical in order to allow the tender to rest fully on it. It can't swing up.......it can only be lowered to approx. 70cm below water level and once raised it stays at the same level as the fixed part of the swim platform.
Regards,
Tarek
Thank you for the info Tarek.
I was not aware of it being standard to the 78.
PropBet is offline   Reply With Quote
Old 06-10-2008, 05:14 AM   #138
TK-F430
Senior Member
TK-F430's Avatar
Quote:
Originally Posted by FISHTIGUA
Tarek,
.........I have seen the Sunseeker system which also moves in a semi circle when being lowered......their swim platform actually moves away from the boat when being lowered. I prefer the Fairline system which allows the platform to move in a vertical direction when being lowered. I'll take a shot of the Fairline system and post it here.
TK-F430 is offline   Reply With Quote
Old 06-10-2008, 11:43 AM   #139
PropBet
Senior Member
PropBet's Avatar
A picture of it retracted (folded up) would be awesome if possible.
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is Off
HTML code is Off
Forum Jump
All times are EST. The time now is 05:46 AM.
Click for Dyna
Click for ISA
Click for Oceanco
Click for Horizon
Click for Rybovich
Click for Glendinning
