Click for Horizon
Click for Oceanco
Click for Sea Spirit
Click for Cheoy Lee
Click for Queenship
Click for Platinum
Go Back   YachtForums.Com > YACHT CLUBS > The Chris Craft Roamer Club > Engines & Running Gear > White crusty mineral deposits on my props and shafts
Reply
Old 06-15-2005, 09:44 PM   #1
wrectec
Registered User
I have had these deposits for several seasons. I wire brush them before put in and by hual out they are back. Senaca Lake N.Y. home port. CC alum Roamer. Any ideas??
wrectec is offline   Reply With Quote
Old 06-15-2005, 10:37 PM   #2
Garry Hartshorn
Senior Member
Garry Hartshorn's Avatar
Location: I have an old homestead about 3 hours drive west of Sydney but I am hardly ever there
Not familular with your area but would suggest it is calcium deposits from marine organisims not a big problem but can usually be resolved with antifouling which depending on usage wears of propeller tips quite quickly but will usually stay on the shaft and the hub of the prop.
Garry Hartshorn is online now   Reply With Quote
Old 07-08-2005, 11:53 PM   #3
alloyed2sea
Moderator
alloyed2sea's Avatar
Surface corrosion
Hmmm,..., could also be very slight electrical current differences generated by props vs. rudders vs. hulls - all connected to your shaft bones. Some folks use circular wire brushes on the shafts on the inside of the hull to "bond" them to the hull bone.
Anybody else got the details?
__________________
Redman
alloyed2sea is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
All times are EST. The time now is 04:18 AM.
Click for Lurssen
Click for Christensen
Click For Dockwise
Click for Westport
Click for Dyna
