Click for Abeking Click for JetForums Click for Westport Click for Abeking Click for Burger
Muffler question
Discussion in 'Chris Craft Roamer Yacht' started by CVS, Jun 13, 2012.
  1. CVS
    CVS New Member
    Knoxville TN and Galveston TX
    Have located some new old stock neoprene mufflers (that apparently are no longer being produced.) They are new, an appropriately sized for my 427 FE Fords at 300HP. Advertised as being much better ("80%") than standard mufflers (think the original tin cans on there now from 1966). Also advertised as less backpressure. Supposedly impervious to acids, fumes, liquids, and heat in the exhaust. Nothing not to like, right?
    Anyone have any experience or comment about these Salisbury neoprene mufflers? Especially interested in how they may compare to fiberglass mufflers as to cost, durability and performance. Thanks for any comment you may have.
  2. Laurence
    Laurence Senior Member
    Chattanooga TN
    From Ebay
    Salisbury # M185 – Neoprene Rubber Exhaust Muffler / Acoustic Marine Silencer
    Proven to reduce exhaust noise up to 80% and up to 50% better sound suppression than conventional mufflers. Does not steel power because of excessive back pressure. Manufactured of heat resistant neoprene. Impervious to the corrosive acids contained in exhaust gases. No metal to corrode, rust or suffer damage by electrolysis or freezing. Flexible neoprene construction. Easy to install – a hacksaw and screwdriver are the only tools required. Bushings optional.
    Model: M-185
    Horsepower Gas: up to 185
    Horsepower Diesel: up to 90
    Body Size: 7-5/16” Diameter
    Flange Size: 8-1/8” Diameter
    Length: 19-1/2”
    Standard Inlet/Outlet Size: 4-7/8”
    Free Reducing Bushings Available ( Call for sizing )
