Click for GPlink
Click for Delta
Click for Lurssen
Click for Trinity
Click for Cape Scott
Click for Ferretti
Go Back   YachtForums.Com > YACHT & BOAT FORUMS > SportFish Yachts > Donzi/Roscioli Yacht > Buying 54' Donzi
Reply
Buying 54' Donzi
Old 02-29-2012, 04:56 AM   #31 (permalink)
Registered User
Donzi 54's Avatar
You should have 3" shafts in that model. Mine came with 3" and don't see any reason why Roscioli would have changed.
Take a hard look at the rudders on that boat mine had to be replaced with stronger models made by Western Branch Metals. The original ones where made very thin, knife like and had issues with vertical cracks near the rudder stock. But that said they where not designed to run at the speed my boat is now capable of doing. And I never noticed the cracks till a year or two after the re-power. I know Roscioli redesigned them but I don't know if that was done on the 54's or not.
Donzi 54 is offline   Reply With Quote
Old 03-04-2012, 09:45 AM   #32 (permalink)
Registered User
I seatrialed the boat Friday and everything went well so I'm moving ahead with the purchase. The boat ran and handled well. Cruised at 24-25 knots at 78% load and easily came up to full RPM and ran about 31 knots WOT. These numbers were with close to full Fuel and water.
The shafts in this boat are definitely 2.5". No idea why they wold be different than some of the other 54's out there but it is.
The boat definitely needs some TLC and I'll start getting systems serviced and back on line immediately. i received an acceptable credit from the seller to deal with deferred maintenance so overall I'm very satisfied with the deal
I was particularly impressed with how the boat turned both at higher speeds and at idle. Cruising thru the harbor in low idle with only one engine in gear and the steering still responds quite well. It only takes about 7-8 degrees of rudder to steer straight with one side in gear.
Thanks for everyone's input. It really helped. I'm sure I'll be back on here soon to ask a lot of questions. The seller I have dealt with knows little about the boat so I'm left to figure out most of the systems myself. At least I was ale to get all the original manuals and info so that will help tremendously.
DOCKMASTER is offline   Reply With Quote
Old 03-04-2012, 10:14 AM   #33 (permalink)
Senior Member
SHAZAM's Avatar
Quote:
That seems very un-donzi like.
SHAZAM is offline   Reply With Quote
Old 03-04-2012, 10:37 AM   #34 (permalink)
Senior Member
AlfredZ's Avatar
Congrats are in order then, best of luck with it.
Cheers.
AlfredZ is online now   Reply With Quote
Old 03-04-2012, 10:40 AM   #35 (permalink)
Registered User
Quote:
I hear you but can't see it as a reason to not buy the boat. Does any disagree? It's not like at 2.5" the shafts are considered undersized by any means.
Old 03-04-2012, 01:09 PM   #36 (permalink)
Senior Member
No, if the shafts are properly sized for the horsepower, then I don't see any reason that would be a deterrant.
Capt J is offline   Reply With Quote
Old 03-05-2012, 02:46 AM   #37 (permalink)
Registered User
Donzi 54's Avatar
Looking back though an original brochure it says that the 2.5" shaft was standard with the 12v92 engines.
Good luck with your purchase
Old 03-06-2012, 08:20 PM   #38 (permalink)
Senior Member
SHAZAM's Avatar
I own a 65' Donzi and just finished up rebuilding the entire machinery space. Based on my experience with my Donzi as well as others that I'm familiar with, I thought 2.5" seemed a bit undersized. Regardless, congrats on the purchase.
Old 03-06-2012, 09:51 PM   #39 (permalink)
Senior Member
It all depends. The smaller the shaft, the less drag and theoretically more speed. I worked on a 75' Jim Smith with 2000hp 16v2000's that had 2 1/2" shafts, but they were a special shaft that was splined like an outboard and didn't have a keyway, making it stronger for it's diameter.
Old 03-08-2012, 11:27 PM   #40 (permalink)
Registered User
Where can I find the brochure you mention? Is it online? That would be interesting reading.
Old 03-10-2012, 07:11 AM   #41 (permalink)
Registered User
Donzi 54's Avatar
Don't think you will find much on-line about the 54. If you like PM me you email and I will send you a scan of it. I also have a boat review article from Boating Magazine from 1995 about the 54 which is interesting.
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is Off
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
All times are EST. The time now is 05:23 PM.
Click for Bertram
Click for Garcia
Click for JetForums
Click for Llebroc
Click for Westport
