Click for Rybovich
Click for Heesen
Click for Rybovich
Click for Shadow
Click for Queenship
Click For Dockwise
Go Back   YachtForums.Com > YACHT & BOAT FORUMS > Motor Yachts > Delta Yacht > Delta 124' "Marama"
Delta 124' "Marama"
Review Tools Rate Review
Delta 124' "Marama"
Delta 124' "Marama"
9,200NM! That alone says a lot about this yacht. In particular, it says that this yacht is capable of being a globe trekker. Delta Yachts, in conjunction with Setzer Design have formulated a practical and robust design that is 124 feet long and called "Marama".
The long-ranged Marama is an interesting project, due to be launched some time at the turn of 2008. With traditional lines and soft edges, Marama will have a classic, but modern style.
Her color, according to the renderings suggest that she will have a gray hull with a blue and red boot-line. The superstructure will feature a white paint finish. The paint will be Awlgrip on the composite structure.
On the inside, Marama will make 6 privileged guests feel at home. They will be served by 6 crew members. It can be imagined that she will feature 3 guest rooms with a capacity of 2 persons each. The owner's suite seems to be included in this as well. It is said that her interior will feature, mahogany wood to give the feel of classic sailing yachts.
Marama will be a phenomenal cruising range of over 9,000NM. This is far greater than most yachts of her size and even larger. She is to be built in a robust manner for the conceived encounters in the Pacific. This is where she might spend a lot of her time.
Her 9,200 NM range is perceived to be attainable at an economic speed of 10 knots. She will have a slightly faster maximum speed of 13.5 knots. To provide the power for the speed, Marama will have 2 CAT 3412E, 650 Bhp at 1800 RPM.
For technical figures you can see below:
LOA: 124’/37.8 meters
LWL: 114’-8”/34.95 meters
Beam: 28'-3"/8.61 meters (molded), 29'-2"/8.89 meters (extreme)
Draft: 10’-4”/3.15 meters (half load)
Displacement: 430 long tons (half load)
Engines: (2) CAT 3412E, 650 Bhp @ 1800 rpm
Max. Speed: (half load)13.5 knots
Cruise @80% MCR: 13 knots
Fuel capacity: 23,600 US gallons
Range: 9,200 nautical miles @ 10kt
Generators: (2) Northern Lights 65 kW, (1) Northern Lights 40 kW
Stabilizers: Quantum QC 1800 Zero Speed
Bow thruster: Quantum QT 120 Hp
Fresh water capacity: 2,200 US gallons
Water-makers: (2) Sea Recovery Aquamatic 1800 GPD
Air-conditioning: Dometic Environmental 36 Ton
Paint: Awlgrip
Material: Composite
Owner and Guests: 6
Crew: 6
Classification:
Naval architecture: Delta Design Group
Exterior styling: Setzer Design Group
Interior Space Planning: Setzer Design Group
Interior Design: Rothschild Designs and Setzer Design Group
Builder/Year: Delta/2008
For more on the Delta Marine "Marama", visit the builder's website, as well as the exterior stylist's website at:
http://www.setzerdesign.com/Pages/Marama.html
Review Tools
Rate this Review
Rate this Review:
Forum Jump
All times are EST. The time now is 06:51 PM.
Click for Moonen
Click for Benetti
Click for Oceanco
Click for NVTI
Click for NorthCoast
Click for Moonen
