Click for Delta Click for Glendinning Click for Abeking Click for JetForums Click for Nordhavn
New Launch: CRN 60-meter "MS"
Discussion in 'CRN News & Launches' started by Yacht News, Sep 1, 2008.
  1. CRN launches the 60-meter displacement yacht "MS"
    On the 30th of August 2008, the CRN shipyard launched its latest yacht. The 60-meter "MS" touched the water for the first time in the midst of a gathering of people at the shipyard. "MS" is a sister to the "Givi" which has the same length.
    "MS" was known under the yard number 123 and built from steel and aluminum. She carries an overall beam of 11.20-meters and a fully loaded draft of 3.20-meters. Fully loaded the MS will weigh 950 tonnes. Her top speed will be 17 knots with the aid of her 2 X CAT 3516B engines and range at 12 knots will be 4,000 NM.
    The naval architecture for the MS was done by the CRN engineering team. The exterior styling was penned by Zuccon International Project while interior is designed by J.L. Mainguy. She is classified to the following:LR 100-A1-SSC- "Y", MONO, G6, *LMC MCA compliance.
    Specifications:
    LOA: 60.00 M
    BOA: 11.20 M
    Draught: 3.20 M
    Materials: Steel (hull) ; Aluminum (superstructure)
    Displacement:950 tonnes
    Engines: 2 X CAT 3516B
    Speed: 17 knots ; 16 knots
    Range: 4,000 NM at 12 knots
    Fuel: 120,000 LT
    Water: 30,000 LT
    N/A: CRN
    Design: Zuccon International Project
    Interior: J.L. Mainguy
    Builder: CRN
    Year: 2008
    CRN Shipyard,
    Via Enrico Mattei, n. 26
    60125 Ancona (AN)
    Italy.
    (+39) 071-5011.111
    (+39) 071-200.008
    http://www.*************
