Click for CL Yachts 99X Click for Burger Click for Westport Click for Ocean Alexander Click for YF Listing Service
Gallery of Crescent Yachts
Discussion in 'Crescent Yacht' started by YachtForums, Oct 24, 2003.
    102' Crescent - "Miss Michelle"
    104' Crescent - "Flipper"
  3. YachtForums
    112' Crescent - "Centinella"
  4. YachtForums
    Another shot of Centinella...
  5. YachtForums
    114' Crescent - "Anchor-W"
  6. YachtForums
    115' Crescent - "Krisha"
  7. YachtForums
    115' Crescent - "Warrior"
  8. YachtForums
    Another shot of Krisha...
  9. YachtForums
    116' Crescent - "Loretta"
  10. YachtForums
    120' Crescent - "Patti-Lou"
  11. YachtForums
    120' Crescent - "Valkyrie"
  12. YachtForums
    121' Crescent - "Crescent Lady"
  13. YachtForums
    127' Crescent - "Dakota"
  14. YachtForums
    96' Crescent - "Miss Iloilo"
  15. Badke
    Badke New Member
    Nelson, BC
    is Necktor of the gods the same boat as Dakota? Crescent website says Necktor is 121 trideck, while Dakota was 127' trideck!
  16. Hawk
    Hawk Senior Member
    Vancouver BC
    Nectar of the Gods and Dakota are the same yacht. Nectar of the Gods was extended adding more space into the aft crews quarters in a 2002 refit done at the Crescent Yard in Vancouver.
  17. Badke
    Badke New Member
    Nelson, BC
    Thanks Hawk, i figured thats what it was a refit extension! I wonder about the process involved in adding length at water line. Structural integrity,possible leaks or what have you. extending decks would be easier id imagine.
    What has been your favorite Yacht to be apart of?
  18. Hawk
    Hawk Senior Member
    Vancouver BC
    Extending fiberglass boats is only marginally harder than a metal boat. You have to be aware of the fiberglass overlaps required to maintain the integrity of the hull which requires stripping the interior and exterior surfaces a little more than with Aluminum or steel. You then extend the hull by attaching plywood to the exterior surfaces and use that as the mold and build as if it was brand new. All in all, not that hard to do. Biggest issue to study and be aware of is increased buoyancy in the stern.
    Favorite boat to date the “MV Valkyrie”
