Click for Mulder Click for Furuno Click for Mulder Click for Westport Click for Nordhavn
Aluminum Hull Roamer
Discussion in 'Chris Craft Roamer Yacht' started by bolsado, Feb 23, 2014.
  1. bolsado
    bolsado Member
    Sacramento
    Established "NEW" waterline with interlux 2000E level with rear chrome mount.
    This is my revised limit for the under water prep and paint.
  2. bolsado
    bolsado Member
    Sacramento
    conditon upon arrival in CA
    The journey from Kenosha to CA was a bit tough on some of the old marine bondo work by the PO
  3. bolsado
    bolsado Member
    Sacramento
    So off to stripping the transom first
    Tried a few things. The coal tar bottom paint was a major pain. The yard cried uncle, I then tried a small soda blaster and then moved up to a sand blaster.
    I found that a mixture of soda, sand and glass media did the trick. Soda took off the paint fine but not the orig chris craft fairing bondo
  4. bolsado
    bolsado Member
    Sacramento
    then used epoxy primer base coat
    Interlux 2000E on sanded and degreased bare aluminum
  5. bolsado
    bolsado Member
    Sacramento
    Then glass filler
    Used dynaglass fiberglass filler
    Found this stuff to be most affordable but has quick set up time and is kinda lumpy especially as it sets up under application in summer temps.
    Typically this stuff is sanded smooth.
    I used this up to the "NEW" waterline.
  6. bolsado
    bolsado Member
    Sacramento
    Interlux glasstite filler
    Used this product as a final smoothing coat, much more workable
  7. bolsado
    bolsado Member
    Sacramento
    upper hull
    I did paint in lifts to make tape lines at water stripe and upper strip so that I could match them.
    Sanded hull sides and spot fairing in spots the painted with the interlux 2000e
  8. bolsado
    bolsado Member
    Sacramento
    toe rail and moulding strip
    Sanded to bare metal, interlux 2000e and watertite fairing
  9. bolsado
    bolsado Member
    Sacramento
    OK back to the coal tar
    On the hull sides I chose to go with sanders. Lots of hard work.
    Advice to those wanting to do this job, rent a commercial blaster and do it in one big push. It was my orig plan but here in CA the yards are under too much enviro scrutiny.
    Find a barn or rent a shop and do in a weekend, time lapse here is a summer and spring for this one man band
  10. bolsado
    bolsado Member
    Sacramento
    At Name Change??
    At this point I was thinking of going with a PT-109 theme
  11. alloyed2sea
    alloyed2sea Moderator
    Alex, VA
    Not so much PT-109 as, say,...
    ..., JAWS!
    I mean, it would have to be subtle - kinda melded into the background of the paintwork, with soft metallic undertones shifting left and right depending on the angle as the boat passed by, soft & soothing but with a concealed snarl -ROAR! Definitely requires a master painter: FOOSE!
  12. bolsado
    bolsado Member
    Sacramento
    My what bright eyes a roamershark has
    All kinds of possibilities with vinyl wraps
    I have considered it for a brushed al stripe and for transom
    3m also has some heavy duty stuff used in commercial construction that mimics wood stone and metal
  13. bolsado
    bolsado Member
    Sacramento
    3m di-noc
    U name they have it
    Marine teak
    Mahogany
    How about marble or carbon fiber
  14. K1W1
    If you do go for a foil finish please post back with your results, I am very interested to know how this works in the real world on a yacht.
  15. bolsado
    bolsado Member
    Sacramento
    Sail Boat in Brushed AL
    I got the idea from a few aluminum hulled sail boats
  16. bolsado
    bolsado Member
    Sacramento
    3M Dinoc on boats
    It seems the di noc crowd loves the carbon fiber look.
    There are hundreds of examples on cars, here is a couple boat applications
  17. K1W1
    Not quite the thing I was looking at
  18. bolsado
    bolsado Member
    Sacramento
    I think its best applied under cover
    How about birds eye maple interior
    or exterior brushed al stripe
    Probably have to replace every few years on exterior.
  19. bolsado
    bolsado Member
    Sacramento
    Finishing touchs on primer and filler
    Final smoothing coat of watertite filler
  20. bolsado
    bolsado Member
    Sacramento
    Final coats of 2000e
    White and Grey
