Click for Abeking Click for Northern Lights Click for Westport Click for Cross Click for Nordhavn
Cutlass Bearing Removal
Discussion in 'Chris Craft Roamer Yacht' started by lacabina, Mar 22, 2010.
  1. lacabina
    lacabina Member
    woodstock georgia
    Any one have a good way of removing the cutlass bearings from the struts. The ones in there now are in a brass casing. This was a mistake and needs to be corrected. My mechanic is thinking about taking a hacksaw to them. The pounding has only moved it a few milimeters and they are afraid of cracking the strut weld. Any good ideas? Thanks
  2. K1W1
    Taking a hacksaw to them is probably the only way you are going to get them out at a reasonable cost.
    You will need to be really careful when cutting through the bearing sleeve that you do not cut to far into the strut. This is because the natural tendency with a hacksaw cutting the pipe lengthways which is what you are doing here is to rock it a bit and cut through at the ends first leaving a not inconsiderable amount of material in the middle.
    How big is it and is there anyone close by who could possibly line bore it out for you without charging an arm and a leg for the privilege?
  3. Kiwipushrod
    Kiwipushrod New Member
    Trempeleau Wisconsin
    Cordless SawZall, no rocking. Done.
    Kiwi
  4. JustMag
    JustMag Member
    Cincinnati
    Would a tool like this help at all??? I'm sure you could probably make this yourself. I'd be worried about using a hack saw
      16.6 KB
  5. Beau
    Beau Senior Member
    Beaufort, NC
    There are several good tools already available for removing a cutlass bearing easily, which most quality shops have on their bench. Hack saw blades, heat and sledge hammers will work, but are a little primative
  6. m2m
    m2m Senior Member
    newport ri
    Hacksaw or Sawzall will work they are just time consuming. The best method is a hydraulic puller if your mechanic can get his hads on one, lots of boatyards have these today perhaps he has a friend that will lend him one.
    I agree, also Cutlass bearings come with a brass outer shell usually. If the old ones take a lot to remove chances are the new ones will fit loosly, you want them tight. If the new ones slide in and out easily, you want to take them to a machine shop and have them knurled (outer shell) so they fit tight and coat them with red locktite.
  8. Since this is the 90s, ya gotta update to new technology! The new bearings you need are phenolic resin shell units. I can almost gaurantee with little uncertantity that the new ones will need to be pressed back in s well. I'm on my third set in 35 years. I also just did my 65 foot Hatteras bearings last year. Thats 3 per shaft. Those struts are bronze and the bearings need to be pressed out as well. A hydraulic pusher can be made out of a GREENLEE knockout tool. Usr a quality Simplex stud, not the chocolate **** from the hardware store! ws
  9. Henning
    Henning Senior Member
    Ft Lauderdale FL
    Sawzawl, cut it into 1/4s doing a doublr cut at one joint to make a "V" groove then chisel the bits out. That's the way I typically do it on struts.
  10. jdpeterson
    jdpeterson New Member
    Fort Myers, Florida
    You might want to check-out the non-hydraulic tool at strutpro.com. Looks like a simple, straightforward press. I've had zero experience at either this tool or replacement, just spied the advert in Sail.
  11. Capt Fred
    Capt Fred Senior Member
    Long Beach CA
    I have had good luck with a threaded puller. From my experience, most bearing are held in with set screws in addition to the press fit, they tend to get hard to see with years on paint and growth. These screws are a little hard to remove because a good practice is to deform the threads to make sure they stay in place.
  12. jflongwell
    jflongwell Member
    Watkins Glen on Seneca Lake
    Audio Credits
    No audio credits?
    John
  13. lacabina
    lacabina Member
    woodstock georgia
    thanks
    Thanks for all of the feedback. I was not present when the tech got them out but he did.
    yes I am replacing with non-metallic shell bearings. Marina just informed me they are on back order. Searching for a supplier with them in stock. Suggestions appreciated.
    happy boating
