Click for Delta Click for Cross Click for Ocean Alexander Click for JetForums Click for Burger
Shaft & Rudder Isolation
Discussion in 'Chris Craft Roamer Yacht' started by Alanglois, Apr 2, 2008.
  1. Alanglois
    Alanglois Member
    Mentor Harbor Yachting Club
    We'll be doing the hull this spring and on top of the blasting/etching/priming/painting confusion we will be isolating the shafts and rudders as they were not originally isolated from the factory. The question here is how do the rudders get isolated with the mechanical steering setup? Also there is a grease fitting at the bottom of the rudder log - what type of grease is to be used here? Is there any concern for type of grease given that it will contact the aluminum rudder log and the stainless steel rudder shaft? Will this create a conductive connection?
    Al
  2. q240z
    q240z New Member
    zsedr
    On my 46 Roamer, there is a grease fitting near the bottom of the rudder log. Good luck getting to it. If you have stainless rudders, you're in good shape since stainless and Al play fairly well together. My rudders were plain steel and GAWD are they stuck in place!
