| |  | I need help with marine a/c.... |  | |
09-22-2007, 11:38 PM
#1 | | Registered User
Recently purchased a 38' Roamer Regal 1971, and the vessel has a self-contained marine a/c unit located under the forward bench seat in the dinette.
The current a/c system is 16,500 BTUs. While this was undoubtedly fine for the boat's original home of Iowa, things are very different down here in Florida where the average day throughout much of the year is well over 90 degrees.
Thus, the boat needs more a/c capacity than it currently has, probably somewhere around 25,000 BTUs total. Though that is only a rough guesstimate, I know it is probably in that range.
My question is how to accomplish this? As you know, these have one shore power plug running 110v. The only single a/c units with enough cooling capacity that I can find run on 220, which is obviously a no-go. So it looks like a second self-contained unit is required.
Will I have to install a second shore-power cable, or can I run two units...say the 16,500 BTU and another 10,000 BTU, on the same cable, or am I going to have to install another shore power inlet?
The genset should be a non-issue, since the maximum power draw at startup for the two a/c units I am looking at is still well under 4kw and the unit has a 6.5kw capacity. So, ideally, I should be able to run both units plus accessories (water heater, stove, etc.).
Any tips? Anyone know what total BTU capacity would be adequate for the boat? What about the second shore-power cable? Advice appreciated!
09-26-2007, 12:15 AM
#2 | | Moderator
| Not in the sales brochure...,
..., maintenance, maintenance,...., well, you get the idea.
First issue: cooling radiator - past which all of your "intake" air passes: look dirty, gummed up, positively disgusting? Needs to be de-gummed with a strong solvent, and then power-washed.
Yup, a big friggin' mess.
Then, there's the internal copper pipes thru which all of your "intake" water passes. Dont think itz full of calcified (spelled s-c-e-l-o-r-o-s-i-s) mineral deposits? guess agin'
SOLUTION: Find a real marine a/c specialist. 16.5K is exactly what i have on board my 37' Riviera - and ever since I bit the bullet/did the maintenance - that unit has successfully cooled the air 22+ degrees vs. room temp. Buying additional units sounds like the solution (it did to me) - but in reality, it will degenerate too.
Shame really; they also get real hot running so "hard" - now you can rest you hand on it and not get burned.
Fires?
Dont get me started. http://www.geocities.com/boating_mayhem/Fires.html
Cheers!
Eric
__________________
Redman
09-26-2007, 11:48 AM
#3 | | Senior Member
| Agree
I agree, check what you have, clean it and see how it runs. Thats a fair size unit and should cope on most days, depending how much actual space it's cooling.
Otherwise what you could do is have a second a/c unit. Ask any a/c company what they think about the shore power but I would consider a second just to run the a/c. If your concerned about the wiring perhaps leave the current a/c on the current shorepower and have a dedicated shore supply for the second unit. Very easy to do and shouldn't cost to much. If you have a second unit that will also mean a better coverage of air and then at night you can shut one unit down that you don't need.
One more option is to run the second unit off a battery and invertor, this will give you a few hours of a/c without shore power and then your current shore power will run the charger when at the dock. I'm seeing this more often on smaller boats and think it's a great idea. Saves running the genset to much.
__________________
Classic yacht/boat enthusiast and captain.
09-26-2007, 02:03 PM
#4 | | Moderator
| Capt Paranoid,... Quote: | Originally Posted by MYCaptainChris One more option is to run the second unit off a battery and invertor, this will give you a few hours of a/c without shore power and then your current shore power will run the charger when at the dock. I'm seeing this more often on smaller boats and think it's a great idea. Saves running the genset to much. |
..., reporting for duty. Obsessive issue of the day:
Powering hi-amperage units w/inverters.
Scary, really,....,. Anecdotal evidence to support madman ranting: Ran vacuum cleaner on board - supposedly well within limits of inverter's amp capacity. Result: Slowly (slowly) built up enuff heat to melt gauge "2" wires running back to batteries six inches off of the connections to inverter.
Just one man's experience,...
Eric
__________________
Redman
09-26-2007, 04:04 PM
#5 | | Senior Member
| if
Yes if you do half a job this can be an issue (not saying you did, I mean with fitting a/c). There are brand new boats that come with a/c running from an invertor and it works fine.
On load a/c does not draw that many amps, the issue is on start up. You could get a unit with soft start but that would cost way to much, so the best bet is to buy a higher spec invertor to cover the ampage and then some. Also you MUST use the correct wiring and have it fused to cover any issues you might have. It's not like we're talking a 60,000 BTU unit here, a small 12 or 16 can run off a 2500w invertor without any problems, it should have a surge capacity of about 4000w which will cover the startup ampage.
In reality, although this would be a nice feature on the boat, the cheapest method would be to just give it it's own shore power.
__________________
09-27-2007, 04:37 PM
#6 | | Registered User
| Quote: | Originally Posted by alloyed2sea ..., maintenance, maintenance,...., well, you get the idea.
Fires?
Cheers!
Eric |
That's a good suggestion. Can't believe I didn't think of having the existing one serviced instead of putting a new one in.
The installation looks to be 1980s-ish...maybe 1990s-ish at a stretch (still has the old 1980s style 3-knob "AIRRRRRRRRRRR" control panel), and the layer of dust caked on the mechanical unit seems to indicate that it has probably never been serviced at all, let alone to the extent that you are describing.
I guess it was one of those "out of sight, out of mind" things...it just didn't occur to me that it needed service. I figured it was like a house a/c, either it was broken or it was working. I will get the marina to do a service on it and see where that puts me, before installing another one.
09-27-2007, 05:05 PM
#7 | | Registered User
| Quote: | Originally Posted by MYCaptainChris Yes if you do half a job this can be an issue (not saying you did, I mean with fitting a/c). There are brand new boats that come with a/c running from an invertor and it works fine.
In reality, although this would be a nice feature on the boat, the cheapest method would be to just give it it's own shore power. |
Yeah, I too have seen people running a/c units off inverters but I always kinda scratched my head when I saw that. It is certainly possible to do it, and have it work just fine, but when you figure how much battery capacity you'd need to get any decent runtime out of it, it's mind-bogglingly expensive for what you get out of it.
You'd need six or eight series 27 or 31 batteries just to comfortably make it through the night with a 16,000btu unit. Each battery is going to run between $100 and $200, plus figure another $1,500-$2,000 for an inverter capable of running that load for long periods. Even if you are going to wire it yourself, you still end up paying almost as much as you could get a nice used genset for...which you could also install yourself if you're inclined to.
The main argument in favor of inverters seems to be that the inverter setup is silent and safer, compared to a genset. In my case, the decision is already made for me since my boat came equipped with a genset that runs fine.
I figure the $600 I would spend for a sound shield is still far cheaper than the inverter setup would be, and the same goes with buying a couple of CO2 detectors to eliminate the safety risk. To be honest, it's not loud enough to bother me....it's located back with the engines, so you barely hear it at all when you're in the forward cabin. CO2 detectors are currently lacking, though, and those will be addressed before I spend the night onboard with it running.
Anyway, my main concern with the second unit was running it dockside, and whether the single 110 power cord would handle the load of both a/c units. It seems like the consensus is to just install another shore power inlet to run the second unit, so I will go that route if I do end up putting another one in. In the meantime I am going to have the current one serviced and see if that improves things.
09-28-2007, 12:00 AM
#8 | | Senior Member
| unit
The 16,000 BTU should pull about 12 amps, so a second shore cable is probably your safest bet to cover any other items on-board and the start up load. I'd almost put money on it that your existing will be fine once cleaned up.
Isn't it amazing how we can complicate something so simple sometimes?
__________________
Posting Rules
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are EST. The time now is 11:46 AM. | |
