Click for Glendinning Click for Cross Click for Nordhavn Click for Burger Click for Burger
Galley faucet replacement
Discussion in 'Chris Craft Roamer Yacht' started by bally, Jul 26, 2007.
  1. bally
    bally Guest
    Anyone have any experience changing one. I look at it from underneath, hard to do and it looks like it will take some maneuvering to get at it. Any suggestions?
  2. K1W1
    Have you ever replaced a faucet in the sink at home?
    It isn't very different as unless it's a hand pump type one you will probably find the same thing at your local Home Depot.
    They generally either have a large nut that goes over a threaded section or a collar that is held up by screws.
    Get right under there with a flashlight and have a look. You should be able to buy the spanner to fit the big nut at a plumbing shop or Home Depot.
    Don't forget to turn off the water before you start to loosen off the pipes!
  3. Ken Bracewell
    Ken Bracewell Senior Member
    Somewhere Sunny
    If you want to practice before-hand I would try the following:
    Climb into the engine compartment of your car and close the hood. Then try changing the alternator. :D
  4. Garry Hartshorn
    Garry Hartshorn Senior Member
    I will have to remember that one. :D
  5. alloyed2sea
    alloyed2sea Moderator
    Alex, VA
    Alzheimers?
    You forgot to remind him to warm up the oil in the motor first. :rolleyes:
  6. Castlerock
    Castlerock Senior Member
    New England
    Go to the plumbing supply house and get a basin wrench. Or you can take the sink out and access it that way.
