Click for Glendinning Click for Westport Click for Westport Privacy Matters Click for Cross
Roamer 38
Discussion in 'Chris Craft Roamer Yacht' started by saundmar, Oct 2, 2005.
  1. saundmar
    saundmar New Member
    Point Edward On.
    Hello all
    I have aquired a '69 Roamer 38 foot steel hull without engines and wonder if anyone has input on diesel re-power. I think the boat was available new with diesels? Maybe 6-53 Detroits? Anyone know what engines might fit without major modifications? I am new to the forums and am glad to find some common interest in old Chris's. Have had a few over the years but my first Roamer. Thanks. Mike
  2. roamertim
    roamertim Member
    Cincinnati Pool, Ohio River
    A Fellow 38 Roamer - but aluminum
    Hi Mike,
    Sorry, I can't help on the engine question, but just wanted to say HI as I've a '69 roamer Regal 38 footer as well. It's aluminum though, not stell.
    It's a fine ship!
    Is yours a regal model?
    Tim
  3. smcmanus
    smcmanus New Member
    KY or MI depending on the season
    The Detroit 6 53's were an original option so they should fit.
    Good Luck
    Steve
  4. Michigander
    Michigander New Member
    Michigan
    Transmissions + Parts
    I have a pair of Paragon transmissions for sale, plus all the hardware for mounting 427's in a CC. These transmissions might work for a diesel conversion. If you are interested, let me know.
    Steve
  5. CaptainRoamer
    CaptainRoamer New Member
    Lake St. Clair
    Steve,
    What are you looking to get for the paragons? WH\hat are the numbers on them?
    Thanks,
  6. Michigander
    Michigan
    Price is $200 each. I'll have to look at them this evening to get the numbers, which I'll then post.
    I also have all the other parts available not part of the base engines, e.g. manifolds, bellhousings, front and rear mounts, marine pumps/starters/alternators, etc.
    Steve
  7. CaptainRoamer
    Lake St. Clair
    Where are the transmissions located?
  8. Michigander
    Michigan
    Here's the numbers:
    LH Hydraulic Reverse Gear - Model HJ7C25-L
    Serial 5E271
    LH Reduction Gears - Model RC25-L
    Serial 5E272
    RH Hydraulic Reverse Gear - Model HJ725-R
    Serial 5E183
    RH Reduction Gears - Model RC25-R
    Serial 5E184
    I'm in Pinckney, Mich. About 10 miles NW of Ann Arbor.
  9. CaptainRoamer
    Lake St. Clair
    Thanks for the numbers. I'm going to check mine to see if they match. Are they both good?
