Click for Westport Click for Abeking Click for Nordhavn Click for Westport Click for YF Listing Service
35 foot roamer
Discussion in 'Chris Craft Roamer Yacht' started by new to roamer, Jul 2, 2012.
  1. Hello
    recently acquired a 1960 35 foot roamer . Just wondering what those little holes are in the hull just below the side windows,just aft the rectangle port holes. Are these for running lights, vents or bilge outlets? Any thoughts??
  2. Laurence
    Laurence Senior Member
    Chattanooga TN
    Windows
    Drain holes for the window frames. Keep clean and open!
  3. my wood window frames have drain holes that run from the inside of the track to the outside. The holes we are asking about are down in the side of the steel hull below the deck level, our roamer was gutted on the inside and there is one hole just below first stringer down aft of the v berth to saloon bulkhead on both the port and stb. sides. I can see a fitting in some of the pictures I have seen of the same boat but I can not identify what it is. these seem a little large and quite far down for another window drain.
    I hope I have explained our query a little better as it will take us a while to put up a picture. Also is there anywhere we can access any technical information for this boat we have the owners manual but it does not help much.
    Thank you for any advice
  4. Hal Swinehart
    Hal Swinehart New Member
    LaSalle, Michigan--Toledo Beach Marina
    I suspect that these are the holes for the running lights. Mine are roughly 18" behind the V-berth ports.
    For more information on your boat:
    http://www.marinersmuseum.org/library/chris-craft
    They have extensive Chris Craft records, including the original Equipment Record for your specific boat. All you need is your hull number.
