Click for Cheoy Lee
Click for Moonen
Click for Quantum
Click for Sea Spirit
Click for Heesen
Click for Crescent
Go Back   YachtForums.Com > YACHT CLUBS > The Chris Craft Roamer Club > Chris Craft Roamer Discussion > Rudder question '58 Steel Roamer
Reply
Old 07-04-2009, 08:10 AM   #16
q240z
Registered User
q240z's Avatar
Gotcha.
I see from your original post that you're stripping it down to steel, so presumably you'll be applying an epoxy barrier coat once that's done. If you're really concerned about losing log material, that would be the time to cut out the old log and have a new one fabricated that can accommodate a bushing. Intuitively (to me, anyway), a bolt-on bushing would be preferable to pressed in one.
Is the original log in bad shape?
q240z is offline   Reply With Quote
Old 07-07-2009, 04:38 PM   #17
biodon
Registered User
There is some pitting around the lower part of the log (on the water side), but I consider them to be solid. I've cleaned them up inside and out. I'm going to coat the inside of the tube with POR 15. I expect it to wear off of the high spots. Hopefully, it will stick to the low spots and retard any corrosion. I decided to leave all the original metal in place rather than remove any material to insert bushings.
I like your complete rebuild idea. I'm not sure that investment is warranted right now. I will have some time to think about it as I've decided to go ahead with the complete hull paint job-inside and out before it goes in the water. I was tyring to get it in the water at least briefly this season before stripping it down. I changed my mind when I exposed a pea-sized rust hole through the hull. It is a discrete hole in the middle of an area with no pitting. It will be very easy to weld shut. It is not what I would consider cancerous, but decided the entire hull needs cleaning and thoroughly inspected to make sure there are no similar spots lurking.
I intend to strip and sandblast the outside of the hull-at least for the water line and below. I haven't decided whether it is prudent to take the upper hull down to bare metal. Was the steel originally smoothed to a paintable finish, or are there factory-applied fillers to make a smooth visible surface above the water line? I have yet to begin my education on new coatings. I trust I will find info in the archived posts.
For the inside of the hull, I intend to wire brush and scrape everything below the water line and coat with POR 15 or appropriate coating. I expect to pull enough flooring to get to every rib joint.
biodon is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
All times are EST. The time now is 12:58 AM.
Click for Platinum
Click For Affinity
Click For Dockwise
Click for Westport
Click for Oceanco
