Click for YF Listing Service Click for Burger Click for Abeking Click for Northern Lights Click for Ocean Alexander
Installing Raw Water Pump
Discussion in 'Chris Craft Roamer Yacht' started by STICH, Apr 27, 2009.
  1. STICH
    STICH Guest
    I Sent My 1966 Chriscraft Roamer Water Pumps Off To Be Rebuilt. I Did Receive Gaskets With Pump. Question: Should You Use Any Dressing On Gaskets An/or Hoses When Installing? Sorry...671m Detroit Diesals.
    I like to use a very light coating of Permatex #2 on the paper gaskets. Make sure your gasket surfaces are clean and flat. You can also put a light coat of engine oil on the gear of the pump if it is gear driven. The impellor area of the pump should already have grease on it if it's a new pump so you shouldn't need to worry about that.
  3. STICH
    STICH Guest
    Thank You,
    I will Install Water Pumps This Weekend.
