Just make sure you have auto bilge pumps capable of pumping out the ingress should the pipe fall off, or turn the supply of when you leave the boat, if your fresh water empties into the bilge from your pump you are only dealing with the amount of water that is already onboard, if it falls off when hooked to shore water you are dealing with all the City has to offer.
__________________
Cheers,
K1W1
