Click for Walker Click for Nordhavn Click for Burger Click for CL Yachts Click for Ocean Alexander
'95 355 Aft Cabin Window
Discussion in 'Carver Yacht' started by seldomdry, Oct 31, 2012.
  1. seldomdry
    seldomdry Member
    Stillwater MN
    I would like to get sliders out to clean track Etc. How does one remove the glass?
    THX
  2. Sea Time
    Sea Time New Member
    Virginia Beach
    I am also interested in how to do this. I recently surveyed a Bayliner motor yacht that I ended up not buying, and it needed the same thing doing. The recommended technique on the Bayliner owners forum was to cut away the felt covered neoprene or rubber track and squeeze in new track underneath the sliding window. They had a link to a place where you can purchase the track in 8 ft lengths.
    Now I'm looking at an aft cabin Carver that will probably need the same treatment. I had started a thread on the possible purchase of a Carver 36, and asked the same question there. It seems the aluminum frame around the windows can be unscrewed and removed. I believe the window can then be removed.
    If I end up proceeding with the purchase of this boat I will probably do this and replace the track as well as sealant around the windows. Hope this helps...
  3. True North
    True North New Member
    St Paul, MN
    I believe Sea Time is correct in that you need to remove the exterior frame to get the glass out of the track.
    Please post when you get it figured out.
  4. adambomb
    adambomb Member
    longisland n.y.
    Did u ever figure out how to get windows out and weather stripping
  5. Thisisit
    Thisisit Member
    Midland, Ontario, Canada
    Removing Windows
    I need to remove the salon windows to get the sofa out for re-upholstering. The window frame needs to be SLIGHTLY spread vertically by way of a porta puller or similar hyldraulic jack. Once the frame is spread about a 1/16 or 3/32 of an inch, the pane can be lifted out. Replacement is just as simple.
  6. adambomb
    adambomb Member
    longisland n.y.
    Ok so I bought the stripping can anyone give me details on how to remove windows or stripping and how to put new in, Thankyou
  7. riverat
    riverat New Member
    Richmond, Va
    Eagerly awaiting
    I'm eagerly awaiting the results of adambomb's removal of his window. I have a 4207 aft cabin that needs a leaky port salon window repaired. I'm hoping he can shed some light on a good technique to remove, reseal and replace.
  8. seldomdry
    seldomdry Member
    Stillwater MN
    Any results to this question?
