Click for Bering
Click for Delta
Click for Walker
Click for Cape Scott
Click for JetForums
Click for GPlink
Go Back   YachtForums.Com > YACHT & BOAT FORUMS > Motor Yachts > Carver Yacht > Carver 430 CMY Galvanic Isolator
Reply
Old 09-27-2011, 12:30 PM   #1 (permalink)
Registered User
Does anyone know where Carver hides the Galvanic Isolator on a 95 Carver 430 CMY?
Thanks,
-Matt
carver43 is offline   Reply With Quote
Old 09-27-2011, 07:13 PM   #2 (permalink)
Senior Member
They're usually installed pretty close to where the boat's shorepower inlet is typically.
Capt J is offline   Reply With Quote
Old 09-28-2011, 01:29 PM   #3 (permalink)
Senior Member
NYCAP123's Avatar
I don't believe you have one on most Carvers. On a 50 amp service you'll often find one prong of the S.P. plug broken off (although some will leave the leg dead). Not sure how it's set up with twin 30 amp. Only boat I'd run with them was a Viking.
NYCAP123 is offline   Reply With Quote
Old 09-28-2011, 01:39 PM   #4 (permalink)
Registered User
Quote:
The owners manual shows one in the electrical diagrams... I'll have to go on a hunt. I'll look around the electrical panel and where the shore power enters the boat. I'm getting some pretty good electrolysis going on and am looking at this as one point to test and eliminate.
Old 10-10-2011, 08:02 PM   #5 (permalink)
Registered User
Thanks everyone, I did find this last weekend. Its immediately behind the AC breaker panel. First place I looked so I didn't have to do much hunting around.
Old 01-08-2012, 05:12 PM   #6 (permalink)
Registered User
Mine has 2 galvanic isolators from Charges (2006 466). They're located behind the closets in the aft cabin, which is really inside the swim platform.
praetorian47 is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is Off
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
All times are EST. The time now is 06:55 AM.
Click for Burger
Click for Llebroc
Click for Cheoy Lee
Click for Horizon
Click for Alexseal
Click for Oceanco
