Click for Westport
Click for Oceanco
Click for Bertram
Click for JetForums
Click for GPlink
Click for Horizon
Go Back   YachtForums.Com > YACHT & BOAT FORUMS > Motor Yachts > Carver Yacht > Power Steering Oil
Reply
Power Steering Oil
Old 09-19-2010, 09:31 AM   #1 (permalink)
Registered User
CroixToys's Avatar
Power Steering Oil
Whilst digging around in the boat, I ran across a power steering oil reservoir that is about half full (empty?). I'd like to see this completely full. Any know what sort of oil goes in there? The stuff in there currently is a clear sort of tawny color. Think auto power steering fluid is good? What kind?
This is on a 1983 32' ACMY
CroixToys is offline   Reply With Quote
Old 09-19-2010, 09:38 AM   #2 (permalink)
Senior Member
FISHTIGUA's Avatar
Quote:
If it's reddish coloured that will be ATF transmission fluid. If it's golden coloured it'll be a steering oil of 15 or 20 weight. That's a very broad brush stroke of a guess, is it a Glendenning system?
FISHTIGUA is online now   Reply With Quote
Old 09-19-2010, 09:43 AM   #3 (permalink)
Registered User
CroixToys's Avatar
Quote:
It is golden in color. I didn't note the manufacturer but will do that next time I visit the old girl. Where might I get some of this stuff?
Old 09-19-2010, 11:01 AM   #4 (permalink)
Senior Member
Pascal's Avatar
Impossible to tell if you don't even know what kind of steering system you have!!! Inboard? Stern drive?
The reservoir may not need to be full so don't ASSume it should be sometimes you need room for expansion
I'd you have inboards and the steering is Hynautics it uses a Gold colored hydraulic fluid available at most marine places although ATF can be used as well. Check the Hynautics site for info
If stern drives (possible on a small boat) then it depends on the manufacturer
Pascal is offline   Reply With Quote
Old 09-19-2010, 11:58 AM   #5 (permalink)
Senior Member
NYCAP123's Avatar
On a 1983 32' I'd guess you're dealing with gas motors and this is the container on the front of the motor. Go to the manufacturer's rep. I know Mercruiser has their own power steering fluid. Make sure you keep dust & dirt out. Add, crank the wheel to each side and top off. Wouldn't bother changing the fluid. May create problems (dirt, improper bleeding, etc.). Never seen it go bad unless contaminated; just leak.
NYCAP123 is online now   Reply With Quote
Old 09-19-2010, 05:39 PM   #6 (permalink)
Registered User
CroixToys's Avatar
It's a HyNautic
Ok, sorry for leaving out details. She's a full inboard setup with twin 350cid Crusaders. I found a manual on the system online and will try to locate oil as described in the manual.
Old 09-19-2010, 08:01 PM   #7 (permalink)
Senior Member
Pascal's Avatar
indeed looks like an hynautic system. it's not power steering, it's just hydraulic. Hynautic makes system with power assist for larger boats but yours is basic hydraulic.
preferably, use hynautic fluid although it's the same as MIL Spec hydraulic fluid available from aircraft part suppliers.
you should be able to use ATF although check your specific system requirements first. the only downsise to ATF is that steering woudl be a little stiffer.
do NOT overfill it !!! keep it between the marks... and you need to use a bike pump to pressurize the system although i can't see the gauge on yours. all hynautics i've seen have a pressure gauge on the reservoir.
good sytem, reliable, little maintenance
Old 09-19-2010, 11:15 PM   #8 (permalink)
Senior Member
Ummm, try reading the label on the side of the unit that is in your picture. It has all of the directions right on it.
Capt J is offline   Reply With Quote
Old 09-21-2010, 09:38 PM   #9 (permalink)
Registered User
CroixToys's Avatar
Yep, not power steering.
Yep, is Hynautic hydraulic steering.
Nope, Doesn't have directions on the side.
Found directions though. Needs HyNautic's oil or aircraft hydraulic oil then pump it up to, I think 40 psi. Currently it is at 15 psi.
Feeling a little sheepish and stupid for posting this though. Shoulda investigated first.
Old 09-21-2010, 10:14 PM   #10 (permalink)
Senior Member
Pascal's Avatar
usually about 20/25 psi is enough...
Old 09-21-2010, 11:54 PM   #11 (permalink)
Senior Member
Anything above 10 is ok......but I would stay around 20-30psi. On an older boat 40 psi might make things leak.
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is Off
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
All times are EST. The time now is 10:27 PM.
Click for Lurssen
Click for Christensen
Click for Cheoy Lee
Click for Bering
Click for DeAngelo
Click for Ferretti
