Click for Nordhavn Click for Delta Click for Abeking Click for YF Listing Service Click for Westport
GPH on a Mariner 350
Discussion in 'Carver Yacht' started by sanjuandreamer, Sep 14, 2009.
  1. sanjuandreamer
    sanjuandreamer New Member
    Everett, Wa
    I have a 98 Carver Mariner 350. Two 454lxi's with V drives. Wondering if anyone out there with the same setup happens to know what the GPH is? I know it depends on what a person carries in it but a rough, educated guess would work.
  2. Capt Fred
    Capt Fred Senior Member
    Long Beach CA
    A rule of thumb is that a gas engine uses 10 gallons per hour per 100 horse power-hour. My 37 Tolly had 330 HP 454s and used 66 gallons per hour at WOT. Cruising at 2700 RPM I used about 28 gallons per hour total and made 17 knots. Your actual GPH will be different but close to this number. Also I find that V-drive are less efficient than straight drives so your consumption will probably be more. Hope this helps.
