Click for Westport Click for Mulder Click for Northern Lights Click for Furuno Click for Perko
Replacing TV in Cabo 43
Discussion in 'Cabo Yacht' started by CSkipR, Dec 12, 2013.
  1. CSkipR
    CSkipR Member
    New Smyrna Beach, Fl
    I need to replace the Sharp TV set that is in the Cabo. This model has two parts. A separate screen and then the internal working parts which are mounted horizontally behind screen. When Cabo installed it they cut a large hole in the wall and the screen was mounted in the hole using some type of bracket in the rear to hold it in place. The outside of the screen overlapped the wall about an inch on each side so it was held in there tight.
    I checked on the Sharp TV model in there and to replace it is over $2000 so I want to replace with a regular HD TV that I can make work for a few hundred dollars. The TV is 30" wide 19.5" high. Any ideas. How would you replace?
