Privacy Matters Click for YF Listing Service Click for Ocean Alexander Click for JetForums Click for Delta
2005 Cabo Express dying problem
Discussion in 'Cabo Yacht' started by COOLBLUE, Jun 20, 2012.
  1. COOLBLUE
    COOLBLUE New Member
    Port Aransas Texas
    540 hp cummins, when you slam the salon door, both engines
    will die out...start back up easy...anyone have ideas??
    Thanks,
    Bill
    If it has the Glenndenning controls, it is in the Glenndenning control head. Back in that era, Glenndenning had issues in the control heads with the sensors moving around (for fwd,neutral,reverse) and such. A lot of them were changed out under warranty. Needless to say the jarring from the door slamming on the Cabo's made them act up because of the proximity to them. Either that or a loose wire........But when they got jostled the control sensors would move around and the computer would shut down under safety reasons...... Check that first...... If both engines shutdown at the same time......Other possible sources could be the shutdown for the fire system, or loose ignition wires...... I generally saw this in earlier Cabo's 2003-2004, because by 2005 Cabo was using the CAT and MAN electronic controls with those engines.......but obviously Cummins no.
  3. Savasa
    Savasa Senior Member
    Iqaluit, Nunavit, Canada
    Don't slam the salon door.....Sorry I couldn't resist....I'll shut up now.
