Click for Westport Click for Ocean Alexander Click for Perko Click for Glendinning Click for JetForums
Replacing seat & cushion foam in Cabo
Discussion in 'Cabo Yacht' started by CSkipR, Apr 3, 2010.
  1. CSkipR
    CSkipR Member
    New Smyrna Beach, Fl
    The black foam in my cushions keeps rubbing against the mesh bottom and little black stuff keeps coming off. The foam actually seems okay but this black stuff always makes a mess. Was thinking about replacing the foam and was wondering what the recommendation were for a good foam or someway to keep the old foam from making this mess?
  2. m2m
    m2m Senior Member
    newport ri
    I have seen this on some older Cabos. I think that the foam you are reefering to is just a thin layer 1/4" or so that sits between the main cushion and the mesh you are talking about. Any good cushion and canvas shop should be able to repair this relatively cheap. Just as a heads up I had to replace the bolster cushions on a Cabo and found that it was cheaper to get the the pre-sewn outer material from Cabo and have a local company install it them on the backing boards
  3. CSkipR
    CSkipR Member
    Foam Cushion
    Thanks for the input. Actually they don't have a thin layer attached its all one solid sheet. I think I'm going to wrap the foam in plastic and see how that works. Great info on the bolsters as I will have to order them in a year or so. Do you have or run a Cabo?
  4. m2m
    m2m Senior Member
    newport ri
    No but I have commissioned and maintained several of them over the years
