Click for Mag Bay Click for Burger Click for JetForums Click for Nordhavn Click for Mulder
Cabo dripless shaft seals
Discussion in 'Cabo Yacht' started by CSkipR, Mar 13, 2010.
  1. CSkipR
    CSkipR Member
    New Smyrna Beach, Fl
    On my Cabo the starboard dripless seal housing around the shaft seems to wobble on the shaft whereas the port stays still. What might cause this and is it of any concern. Its not wobbling alot but is moving. Pretty sure the shaft is straight so don't think thats the problem. thanks, skip
  2. Marmot
    If the shaft is not bent and the seal is not leaking the only thing it can be is the rotor is cocked on the shaft.
    Can you use a dial indicator and check the shaft and rotor for radial and axial position as the shaft rotates?
    This isn't the end of the world yet, but it is a warning.
  3. CSkipR
    CSkipR Member
    Marmot,
    Thanks for the reply. We did put a dial indicator on the shaft and its out about 3 thousands but that could also be the couplers not quite a perfect fit. When I pull the boat this week will check the shaft right where it exits the boat.
  4. Marmot
    Check the shaft seal rotor on its circumference and along the forward face to see if it is cocked or is displaced radially. Even if the shaft is perfect, anything that causes the rotor to sit crooked will make the whole seal wobble. Is the rotor the correct size for the shaft?
  5. CSkipR
    CSkipR Member
    How do you check the rotor to see if it is cocked. Do I take the shaft seal apart? I'm sure the rotor is the correct size since the other side is fine.
  6. Marmot
    The rotor is the stainless steel part that is fastened to the shaft with set screws. Secure your dial indicator on some part of the hull and zero it out on the outer rim of the rotor and turn the shaft by hand. That will give you a radial runout and show if the shaft is bent or the rotor is not centered on the shaft.
    If it does show a large displacement, zero the indicator on the shaft just forward of the rotor and see if it indicates the same displacement. If it does, your shaft is bent, if it does not your rotor is incorrectly aligned.
    If the indicator shows no problems above, zero the indicator on the front face of the rotor and turn the shaft by hand. That will show you if the rotor is sitting at an angle to the shaft centerline, i.e. if it is cocked or displaced axially. This is most likely the cause of a wobble if the shaft is not bent or out of alignment. There are several reasons the rotor could be displaced, too large a bore, junk between the rotor and shaft when it was installed, bore not 90 degrees to face ... that's why manufacturers hire QC techs.
    In any event, make sure you let us know what you find. I am sure you aren't the first or only person to see this and your findings add to the database here. Good luck, hope it is something simple.
    I have also seen Tideseal brands (which have a very very hard plastic/rubber) that rides on the shaft eat 30 thousands out of the shaft where it rides on it and cause the entire assembly to wobble and then eventually it started leaking. The shafts on this boat were only 1.5" and we replaced the shaft, as well as the tideseal, because there was too much clearance for the new seal to seal, and we were worried about strength as well.
  8. Marmot
    Good point J. I (maybe incorrectly) just assumed it was a PSS seal.
  9. CSkipR
    CSkipR Member
    Not sure what kind of seal it is but its not a PSS. What does Cabo normally install?
  10. Marmot
    Can you post a picture? I have read reviews where they have a proprietary seal but dripless seals are mechanical seals so will have a rotor and a stationary face.
    Look up the installation drawing for a PSS seal and see if yours resembles theirs. If so then the dial test procedure is still applicable.
  11. CSkipR
    CSkipR Member
  12. Capt J
    Call Cabo with your hull number and speak to the parts department and they can look up exactly what system your hull has. They'll also have the seals and such......they've switched over the years.....is it a bronze body?
  13. CSkipR
    CSkipR Member
    Capt J it does have a bronze body.
  14. Marmot
    What part are you calling the body?
    If it looks like the second link K1W1 provided, it is a PSS style. The rotor is on the right side of that drawing, it is secured to the shaft. The corrugated looking bit on the left is rubber or plastic and connects to the log. The intermediate part with the tubing barb sticking up is the stationary part of the seal.
    The instructions for checking with an indicator apply to the seal shown in the second link.
    Do you by any chance have a standard packing gland that is mounted forward of the log by a length of stiff rubber hose and not a mechanical (dripless) seal?
    Or is it maybe one of those "bluewater" things that has a lip seal inside a housing that looks like a standard stuffing box connected to the log by a short piece of rubber hose?
    If it is one of the latter, your shaft is either bent or it's whipping and the lip seal won't last long either.
  15. K1W1
    Sorry, I should have added labels to the links.
    The first is a Tides Marine one and the second one is a PSS one as suggested by Marmot.
  16. CSkipR
    CSkipR Member
  17. Marmot
    Like I wrote in #15:
    "... your shaft is either bent or it's whipping and the lip seal won't last long either."
    And the babbit bearing is probably worn out of round. No telling yet if that is the cause or effect. Better check the shaft condition in way of the seal and bearing. Just curious, is that $180 just for the $5 lip seal or is that for the whole job?
  18. CSkipR
    CSkipR Member
    Blue Water Shaft Seal
    Thats just for the seal. Hard to believe.
  19. Marmot
    I would describe it in other more colorful terms. .
